[C2] 427 Variations Question
I've reached the step to start getting an engine for my car. Since we decided here that it was originally a 390/427 car, a big block will once again be in the car. After looking at all the crate choices out there, I just can't find the one I really want. Never thought I would say this, but they either have way more hp than I think I need, or the heads have raised exhaust ports (read that may cause exhaust manifold/header issues) or the intake is too tall, etc. I would like a dependable build staying close to the stock hp range.
Of the 427 variants, is one more preferred than the others for daily driving, long trips etc? No drag strip in the future but possibly the cone courses. Trying to figure out what specs I am looking at as I know what the parts are but do not know what all the numbers mean.
Talking with the local engine builder, we were looking at going with Gen VI block, roller set up, aluminum heads/intake and I am going with the holley sniper.
Here is the block I am looking at as it is actually in stock and found it cheaper than the listed price. The builder said we would probably have to have the crank made since chevy discontinued the one-piece rear seal crank they use for the ZZ427. They still make the engine but don't sell the crank by itself anymore. I don't understand that.
427/454 EngineBare Block: GM Performance Motor
ptjsk (12-17-2021)
Received 3,050 Likes
C1 of Year Finalist (performance mods) 2019
Based on your comments Have you looked at this?
https://blueprintengines.com/collect...ns-br-seasoned
I did look at their engines. I really don't want to buy a new engine that is bored .60 over at the start. I think the next thing up they had was a 502 that was not bored. The rep told me he didn't think the intake would clear the hood, might have issues with the raised exhaust ports and would probably need to change the oil pan. I asked about getting just a short block and he stated that they were not selling those at this time as they are trying to play catch up on the long block orders.
I don’t know about their BBs but their SBs are their own blocks they build. If their blocks are .060 over and the make their own it likely has plenty of wall thickness. regardless they WARRANTY it. The link I sent you are not the tall block so I don’t know why you would have a height problem especially with a BB hood. You may want to revisit this.
I will see what other options they have. The link you posted is for their hand picked season blocks they bore 60 over for that line of engine. The 502 and up are made from their new castings.
Received 6,989 Likes
2015 C2 of Year Finalist
I think a 454HO from GM would fit all the check marks.
These BP 496's are made with their new blocks. They also have roller cams, mech fuel pump and clutch Z-bar boss. However, they still have the raised intake port.
https://blueprintengines.com/collect...-standard-deck
Thanks all. I will look at those.
But was their a difference in driving say the 390 vs 435? I don’t know if you would street drive an L88.
Im going to do the GMPP ZZ427. Conservatively rated at 430 Hp and over 500 Lb/ft aluminum heads and it’s complete from oil pan to carb. I don’t think you can beat it , and it’s got a warranty.
Chris there is a huge difference between a real 435 and a 390, now an L88 with an idle speed of 11 or 1200 RPM you have to work it to get going, but once moving it’s downright scary, it’s simply a race car on the street. I prefer solid lifters over hydraulic lifters. The 390 is hydraulic.
My 65 BB coupe came from the factory with a small block. A NASCAR owner built the car for his wife and installed a 427 engine from an Impala SS 427. The engine is rated from the factory as 385 horse ( 390 ) with hydraulic lifters and stock Holley 750 CFM Carb. It is a two bolt main engine and is mated to a Richmond Six speed transmission. It has a Comp cam and Rhoads lifters which I installed. The car pulls hard and drives very nicely and with the side pipes sounds really good. The car was auto crossed successfully in the past. Also plenty of hood clearance with my hood and BB stock air cleaner. Hope this helps. Fred
marshal135 (12-17-2021)
If you're going to build your own engine using the bare block in your OP, why wouldn't use simply use the crank with the one piece rear seal that the same company sells?
https://www.gmperformancemotor.com/parts/10183723.html
Reading Gavin65’s post—my vintage racer 66’ L72 is orig motor but pretty much L88 spec— idle is 1250 (has to be or she loads up), hooker long tube headers. I think it is decently streetable but wife hates it— loud and she hates smell of 112 Sunoco— weird huh? 😀
The following 2 users liked this post by Martyt:
Dad's '66 427 (12-17-2021),
ptjsk (12-17-2021)
How About a Nice GMPP ZZ502 Nice Specs...
508 HP @5200 RPM..What it really is a 454 Stroked..originally built for Marine Applications for low RPM High Torque is needed to twist the props. No need to wind your motor to 10 Bazillio RPM. Will drop right into a C-2. You can get a deluxe ready to run or a Long Block.. Check out the website. https://www.chevrolet.com/performanc.../zz-502-deluxe You will need to chane to a 4 Qt Pan and chage the oil pick up. Now comes with Fuel Pump boss and clutch cross shaft Ball Stud.
580 LB/FT @3600 RPM
What GM Crate Engine Should I Buy?
It turned out to be the perfect choice for me. Everything fit. Everything lined up and it was a piece of cake to install. It has aluminum heads with roller rockers and big valves. It runs on pump gas and all of the parts of the engine are available over the counter from your local Chevy dealer. It uses an old school fuel pump with a rod that runs off the cam lobe and the side of the block has been drilled and tapped for the piece which holds one end of your clutch cross shaft. It is a well behaved motor with all of the horsepower you will likely ever need. In addition, this motor comes from GM with a two year warranty from the date of purchase.
I'm not sure about the one-piece rear main seal (part # 10101164) having been discontinued by Chevrolet since the GM performance website still lists it for sale at $38.97. The ZZ427 engine comes completely assembled and has already been run and tested at the factory so I never had any dealings with a machine shop or a "builder". GM was the builder and I was the installer. Anyway that's my two cents and if I had it to do over again I would not change a thing. Good Luck with whatever you decide and I have included a couple of pictures for your perusal. C.J.
The following 5 users liked this post by C2Scho:
elwood13 (12-23-2021),
Lotsacubes (12-17-2021),
MarkC (12-17-2021),
mblake101 (12-17-2021),
roadster65 (12-25-2021)
BUT- it looks like you had better grab one before they are all gone, if you have fought one still in inventory!! The 480hp one is the one that most outlets have to sell, and at a big price jump.
Based on what you said you wanted, and keeping the 427 Moniker, I think this is a very wise choice.
Chris,
At the speed this build is going I've got the only option you will soon have
https://www.topgear.com/car-news/electric/you-can-now-make-your-electric-motor-look-v
This is my lame way of subscribing to your thread. No need to thank me.......It's time to go DRIVING! I hear the hill country calling!!
Steve
Steve
Chris,
Steve
Steve
