C2 tail lamp not working
John T here. '63 C2 Roadster. Driver's side outboard tail/break light not working. Inboard back up light OK, passenger side OK. Dual purpose outboard bulb seems to be OK. Difficult to reach the assembly from the back to check it out. Appreciate any suggestions about the best method to track down the problem.
Thanks,
JT
Thanks,
JT
Thanks,
JT
Thanks,
JT
Location: Various places in California. Not currently aflame.
Does it light up at any time? Specifically, does it light up when you operate the turn signal lever to indicate a left turn? If the light works as a signal light, but not as a brake or running light, that indicates the problem is within the turn signal switch. If the light never lights up, the problem is likely more general.
Next test is to determine whether the problem is on the ground or power side. Using a multimeter, is there continuity between the negative contact in the bulb housing an a ground on the car? If so, the housing's ground is good, if not, you know this is the problem. Is there power to the positive contact in the housing when a helper depresses the brake pedal or turns on the lights?
Between these tests, you should be able to identify and fix the fault.
Great advice. Would not have thought of the turn signal test. Yes, the turn signal switch works the light. Does this indicate a problem with the turn signal switch? If so, why?
Thanks,
John T
PS: The tail light function works too - only the brake light is not functioning.
Thanks,
John T
Last edited by joeysc2; 11-13-2021 at 04:48 PM. Reason: My response was incomplete - sorry
If only the driver's side brake light is not working and all else are, the problem is at this contact in the turn signal switch. (sometimes moving the turn signal lever left center right, repeat a few times will clean the contact and the brake light will work). If the contact is bent so it is not touching at the arrow, that will not correct it.
I think we've found the problem.
As for the "why?", if you think about it, the turn signal switch has to control the brake light function because the same bulb filament is used for both functions. When you hit the brakes, the light brightens up, but if you then operate the turn signal, the bulb now flashes. So the turn signal switch has to have a say in whether or not the lamp is on.
The switch is easy to replace, but I think the '63 switch is unique. It can also be repaired, but I have not done that.
You guys are freeking awesome! Got the dang thing fixed! No way a shade tree mechanic like me could ever figure that out your solution. Can't tell you how impressed I am with your knowledge about these early Vettes and with your willingness to share your knowledge - and promptly at that. Happy you're not burning, owe you a beer.
John T.
John T.
65GGvert,
Thanks 65
65GGvert, thanks for the advice and photo. As I mentioned earlier, there's no way I would have figured out your solution on my own. You guys are great!. By the way, we have owned our '63 Roadster for 47 years. It's black, with a black interior and a tan soft top. Equipped with back up lights. Sound familiar?
Thanks again,
John T
Thanks 65
Thanks again,
John T
