[C1] C1 generator bracket indentification
Hi All, I came across a generator brace part number 3760364 with a strange end mount. It is not straight? Can anyone identify it? Thank You!
Shows in the parts book as applying to several cars and Corvettes, 55-62. 14" long, 4 1/2 slot, 5/8 offset.
I am sure the bracket has been bent to be used in a non-stock application. Use heat to soften and rebend the end back to flat or it'll break, actually, it may break anyway, good luck with it.
I had a then new 65 Malibu with the L79 and I had to use double brackets to eliminate breaking the brackets
