New Big Block from Chevy
Probably overkill for a C2 (if it would even fit), But........
https://www.chevyhardcore.com/news/c...k-crate-motor/
Received 1,558 Likes
2020 C2 of the Year Finalist - Unmodified
Looks like the horsepower wars are alive and well.....
Wonder if, after production begins.... they reduce the sticker on the air cleaner to 950????
You know...... for insurance reasons....... LOL
The following 5 users liked this post by Dad's '66 427:
INTRUDR (10-21-2021),
jim lockwood (10-21-2021),
MrTrim (10-21-2021),
ptjsk (10-21-2021),
Westlotorn (10-22-2021)
2021 C5 of the Year Finalist - Unmodified
But it's only got 600 lb-ft of torque at 3,000 rpms?
Good lord.
Good lord.
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
If one shows up at my front door, I'll take it
vjjack04 (10-21-2021)
The following 2 users liked this post by Dad's '66 427:
59BlueSilver (10-22-2021),
Six7390gt (10-21-2021)
Received 6,548 Likes
C2 of Year Finalist (track prepared) 2019
The following 4 users liked this post by jim lockwood:
The following 2 users liked this post by jim lockwood:
Six7390gt (10-21-2021),
Saw this on another site......
"Unlike some of its other high-performance crate engine offerings, GM isn't placing a cap on ZZ632 production, and, in even better news for speed freaks, the engines will be kept in stock rather than being built to order. We don't have pricing yet for this monster of an engine, but we suspect it will land somewhere north of the approximately $16,300 that is being charged for the ZZ572."
Gotta like the 'will be kept in stock' part......
I got it. So did my 66 L72. From 450 to 425
The following 2 users liked this post by INTRUDR:
Lotsacubes (10-22-2021),
Moderator
very interesting.. they compare it to the hellephant, a 426 ci supercharged mopar motor. Pretty impressive that they got 1k hp out of a naturally aspirated motor... though I guess at 632 CI, it shouldn't be much surprise.
wonder how much boost it would take :-)
Received 6,995 Likes
2015 C2 of Year Finalist
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
"how to make pretzels out of driveshafts"
- Engine Type: Chevy Tall-Deck Big-Block V-8
- Displacement (cu. in.): 632 cu. in.
- Bore x Stroke (in.): 4.600 x 4.750 in.
- Block: Cast Iron Bowtie with 4-bolt main caps-tall deck
- Crankshaft: Forged 4340 steel
- Connecting Rods: Forged steel H-beam
- Pistons: Forged aluminum 2618 alloy
- Intake Manifold: Aluminum high-rise single-plane
- Throttle Body: 4500-style
- Fuel Injectors: 86-lb/hr
- Camshaft Type: Billet Steel Hydraulic Roller
- Valve Lift (in.): 0.780 intake/0.782 exhaust
- Camshaft Duration (@0.050 in.): 270º intake/287º exhaust
- Cylinder Heads: Aluminum spread-port; 70cc chambers -RS-X design
- Valve Size (in.): 2.450 intake/1.800 exhaust,Titanium (5/16-in stem OD)
- Ignition Type: 58X crank-triggered, coil-near-plug
- Compression Ratio: 12.0:1 (nominal)
- Rocker Arms: Forged aluminum; roller-style
- Rocker Arm Ratio: 1.8:1 (shaft-mount)
- Water Pump: Aluminum
- Oil Pan: Steel 8-quart
- Recommended Fuel: Premium pump (93 octane or higher)
- Maximum Recommended RPM: 7,000
The following 3 users liked this post by JrRifleCoach:
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Here's a comparison for you....
1004 HP:
1000 HP:
1004 HP:
1000 HP:
INTRUDR (10-22-2021)
