[C2] K66 ignition coils
K66 ignition coils
I new here but I have been a boat mechanic and car restorer all my life. I just purchased a 1967 427 435hp that was in an estate sale and looked to be sitting around for some time. Someone had replaced the distributor with a points one. I have found and purchased an original distributor, and obviously, the there are repro amps available. However I have been unable to find the coil for this system. There are and assortment of repro. coils out there (not made in USA) that are GM registered products however no 1115263 are left and I have resigned to use a different number as they are all built the same. However my research indicates these are not that reliable and everyone that I have talked to say its a hit and miss thing, as far as longevity. Primary ohm readings for the original coils are 0.41-0.51. Since I can't get the 263 coil I was thinking there might be an alternative available Someone had suggested ProTronix 44011 Flame Thrower III would work as it has a low primary ohm reading. I looked it up and it has a primary ohms of 0.31. Most other canister coils are .070 and above. Has anyone run into this dilemma. Please let me know what everyone has experienced with this issue. Thanks
Received 6,989 Likes
2015 C2 of Year Finalist
keep a eye out for NOS 207 coils. that is what GM sold to fit every TI application. stay away from NON GM coils
Dave Strickland (11-23-2021)
Check parts for sale section. "C2 parts for sale" by playswithcars for your coil.
Received 1,544 Likes
Welcome to the forum. The greeting is a formality for demanding pictures of your car. It is kinda like a hotrodder's pinup.
I am no help on your search.
Welcome again.
Ron
Welcome again.
Ron
Received 5,608 Likes
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thanks everyone
Keep the info coming. I have found some used 207 coils but prices are crazy for a used (50+ years old) coil $450+. Is there a way to ID a repro from an original. I think the NOS coils should have
As requested, a couple of pics of my new baby! Now she’s on the rack being cleaned and fixing things that happen when sitting for 20-30 years.
stenciled numbers on them but really to sure if that is right. That summit coil looks good while I keep looking for the right one.
Retired
If it does not, did you ever come up with a coil that will work for your situation? Thanks and you have a beautiful car. Happy Holidays. Mark
Non found
After exhausting a search for a replacement coil and trying to find an actual GM coil I found out this. No one make a coil with similar ohm reading. Some are close but non that close to the originals. Basically you can buy one that might work but it also might screw up the TI box. Long story short. No coils are similar and finding an original is possible but extremely expensive. The re-pops r the only thing that I found new. What I read was these new one are a hit and miss. Some people have been running them with no problem and others complain they don’t last long. I figure I can buy 3 re-pops to one vintage coil. It’s kinda like rolling the dice on these. I ended up picking up one from zip and of course no one has the re-pop with the correct numbers so I had to get the wrong numbered one. PS according to everything I read all the ti coils are the same just different numbers on them. C19 screwed up my build so I’m still waiting on some parts in order to get my car back together and try the cool. Good luck with the used one.
I have a TI system that belongs to my 66. I'm not going to use it. I'm going to rebuild a stock tach drive dist. and install a pertronex system. I don't trust the TI and parts could be a problem. Just ordered the parts to build the new dist yesterday. The whole TI system will be for sale soon.
Received 2,146 Likes
2015 C2 of the Year Finalist
I'm often baffled how so many are willing to discount or downright ignore the painstaking engineering and testing efforts that went into things GM did well. K66 is one of those things if its 10+ year tenure is any yardstick. Why then are so many presumably sharp fellas willing to abandon it for a one size fits all epoxy incapsulated integrated circuit(s) that were intended to fire any spark plug anywhere on anything.
Dan
Dan
Nowhere Man (11-23-2021)
Particularly when the weakest element, the old tech power transistor, has a very robust new tech board you can hide in the amp box. The thing becomes almost bullet proof with old wiring and connectors being the biggest problem.
