Head light motor switch grounding - any damage I should look for
Last night when trying to open my head lights, nothing moved and the circuit breaker I had installed on the power wire coming off the starter everything would trip (glad I installed it now though the CB on the head light motor switch might have tripped if that one was not there). Disconnected both head light motors and it would still trip when the switch was moved in the open direction (but not in the down direction). Dismounted the switch from the gauge cluster and found one of the flat nut's corners had "welded" itself to the slight bare section of the yellow wire (up lead) going into the switch connection thus I assume grounding the switch. Not sure why this would happen all of a sudden after operating the switch for many years, but it did. Used some of that liquid electrical tape to put a healthy covering over the minute section of bare wire, plugged everything back in and motors open again.
So what I was wondering now was could there be any damage in the electrical system because for circuit grounding? I noticed when it happened the amp gauge pegged all the way negative and the temp gauge pegged way past the highest temp to the right, but both those went back to normal positions once the CB closed and the ignition switched on again. Head light motors work and can't see any blown fuses and other things seem to function correctly, but not sure if something else might be broken now and I just haven't tried it yet.
Any thoughts?
Any thoughts?
It sounds like your circuit breaker worked like it was supposed to and protected the wiring from shorting out. If you didn't see or smell smoke you should be OK. Take a look at your fuses just to be safe. Good luck!
Yeah I didn't see any smoke released from any wires or smell anything. Also no blown fuses at the fuse block, will have to check the others I've added.
