[C2] 64 L 76 thermostat housing paint
My bare metal thermostat water intake on my aluminum manifold is rusting. From searching forum, it sounds like it should be painted silver. Do I need to us Hi Temperature paint? Should only get to 180 to 200 degrees. Is there a better product than paint to use on it.
thanks
Craig
thanks
Craig
Regular paint will do.
Eastwood DETAIL GRAY......... or a "Fresh Steel" (or "Stainless Steel" ) color paint will work nicely.
Most lacquer and enamel paints will work to 250-300 F without issues.
Larry
Larry
cramus (07-19-2021)
A bit to "shiney" and "aluminum looking" for me..............but that is OP's decision.
Larry
EDIT: Eastwood Detail Gray is not really gray, but the color of fresh steel or stainless steel. I also had OEM Paint Fresh Steel and Mid-America Stainless Steel paints and all were a dead match to one another. OEM Paint is no longer in business as I recall. Mid-America may still sell their stainless paint.
Larry
I ordered a can of Eastwood detail gray. None of the product mentioned Appeared to be available locally, so I just pick one. Thanks for the help.
Received 6,982 Likes
2015 C2 of Year Finalist
cramus (07-19-2021)
When the Flint engine plant finished assembling your engine, the installed thermostat housing and the area around it on the intake manifold received a coat of dull aluminum paint. (also the area between the manifold and valve covers on the cyl head) Krylon makes a color in a spray can called Dull Aluminum that is just about exactly the correct color.
Powershift (07-20-2021)
Critter1:
I agree. When I did my own car I used what I recommended above...............and was pleased with the outcome. The "Dull Aluminum" would likely have been another good choice.......or the "best" choice for originality.
I don't think OP will be disappointed, but your info is good to get out there for everyone to see.
Larry
Larry
There is still a light coating of dull aluminum paint on the cylinder head gasket surface between the intake manifold and valve cover of this unrestored engine. You can see the line where there was no dull aluminum under the area where the intake manifold covered it during painting. The overspray typically covered the side of the valve cover and some of the intake manifold but the color nearly matched the color of these items so it wasn't noticeable.
