[C2] rear end code ???
Not valid for 67. Post a picture
Here's a 67 rear stamp
AM= 3.36 posi
5 24 67 ***/y date
AM= 3.36 posi
5 24 67 ***/y date
Could be a later C3. Post a pic as mentioned above.
As Jack stated, not correct for a '67. Here's a shot of my '67
AS - 3:70
5 29 67 date assembled
AS - 3:70
You should have two letters at the front. Here is a 78 thread with the W8E.
https://www.corvetteforum.com/forums...tial-code.html
I have no idea since you are missing a letter at the front for all the codes I found.
Maybe like this?
I hope you can see why I asked you twice for a picture.
1976-79 used "O" codes. So the question is not as much what year it is but what condition it is. Was the 67 diff blown up years ago and a cheap core installed? Was it rebuilt before install? The only way to know is to open it up but if it's in good condition, no leaks or chatter it might not be worth it. If it's stock 76-79 then there are some things in it that need attention and the axles are one so I would look to make sure they haven't crashed into the axle seal bore lip yet.
