[C2] C2 (64) Expansion Tank Dented
I don't think that's from over tightening. That looks like something hit it.
It would be difficult to get it perfect. Aside from one of those tack stud guns and a slide hammer (and someone to hold it while you work the slide hammer) I cant think of anything else. Maybe take it to a custom motorcycle shop? They may have a suggestion.
Looks like someone has already tried to fix that nipple. What does a new one cost?
Received 5,605 Likes
DeWitts makes reproductions with the correct date codes.
TRP_IV (07-10-2021)
You might try putting an M80 firecracker in and run. I've seen it done. It works!
Also be sure to put a heavy blanket over the tank so that when it jumps it doesn't re-dent itself.
pop23235 (07-11-2021)
If you try the M80 trick you might end up with a burp tank shaped like a watermelon.
OC-1 (07-12-2021)
