[C2] Front End Alignment
2023 Restomod of the Year Finalist
Front End Alignment
Can’t seem to get my steering wheel centered correctly, it’s either a little to the left or to the right. And it affects my turn signal cancellation. Think I need to get my 65 aligned but haven’t been to an alignment shop in over 20 years. Can any shop do it, Firestone for instance? Looking for a recommendation.
In my experience with front and rear end alignments on C2's it's not so much the shop as the alignment mechanic who works at the shop. A few years ago I was struggling to find an alignment mechanic in the area who had a clue as to how to correctly align a C2 and I was having no luck. Finally I was at a car show and asked several different C2 owners who live in my immediate area that question. They knew exactly who to go to and it was mechanic specific; not this shop or that shop. I would check with friends of yours who live in your area and who own one or more C2's. There are only two mechanics/locations in my area (Northern Virginia) and they are both well known to local C2 owners. Everyone else is clueless. And as you might guess, both of the alignment guys in my area are in their late 60's and early 70's. Good Luck with it.
59BlueSilver (04-20-2021)
Just had mine done - and no, you can't trust any shop to do it. Most of the young kids in the boutique shops won't know what an alignment shim is. Ask you car buddies or the local NCRS outfit for a good recommendation.
The following 4 users liked this post by Frankie the Fink:
Received 1,977 Likes
First review the shop manual and AIM to verify that the system is properly assembled. There are various index marks that need to be lined up.
If it's assembled properly then it's just a matter of tweaking the tie rods to center the steering wheel while keeping the toe-in in the proper range. If it only slightly off you can usually tweak just one tie rod. Any alignment shop can do this simple task, but so too can any decent DIYer.
Duke
Duke
If you're gonna do it, go the whole enchilada and get the 4 wheel alignment, you will prob have to bring your own rear shims (get stainless steel from any vendor here) and bring your OWN specs. Most of the databases on the whiz bang, laser machines won't go back to the 60's.
Pro Mechanic
Received 1,334 Likes
2023 C1 of the Year Finalist - Modified
Received 5,708 Likes
You've got to be kidding. I doubt there are even a few shops that know anything about a 65 Corvette front end let alone the rear. If it was a "reputable" shop they would have a lot of cars waiting and once they found out what it takes to set a C2 rear toe in they would probably refuse because they'd have lots more easy paying customers to do instead.
I only go to a specialty shop near me, and they set it to my specs, not to a "good enough" setting. The owner is a racer and does a lot of older cars.
Pro Mechanic
Kidding about what ? I may have not made it clear in this thread but I've said it 10,000 times before to find a shop that knows what they're doing and showed my car a dozen times on an old Visauliner machine from the 60's right here in my town. That gentleman is no longer around so I took it to Palm Automotive (a modern shop nearby with an old school alignment tech), it took him an hour on a modern machine and cost $135
I did my homework and the guy that did mine was very experienced, moreover when replacing the trailing arms I preserved the shim pack positions and that paid off - those didn't need touched, nor the front set up. The rear camber was the only thing way off...
Now, a few here have gone to boutique alignment shops and told their cars are classified as "exotics" and an alignment for all 4 wheels will cost $400 or more.
Pro Mechanic
As was mentioned briefly above, my biggest concern with having a modern shop do the job is whether all the bolts and nuts that need to be loosened will still do so. I'd also be concerned about whether the rubber wear items were too far gone to do a proper alignment. So if my only ocncern was centering the steering wheel, I'd follow SWCDuke's advice and do it myself (like I have done in the past). If I decided to go for the whole 4-wheel alignment, I'd do a thorough inspection of front and rear suspension and test loosen (and retighten) any suspicious looking bolts/nuts. I'd also be prepared to show the technician where all the alignment adjustments are made.
Frankie is more than capable of responding and defending his position, but this post is out of line and simply rude. Reading comprehension is a critical skill. Hard to believe you are lacking in that department, therefore the only conclusion I can draw is you are resorting to attacking the individual vs. being able to defend your position. Disappointing.
I was able to work with a friend at a local Chevrolet dealer on my 67 alignment with a newer Hunter machine that downloaded the specs from their website. I would start with getting the steering wheel in the correct position so the turn signal cam works. I clamped the wheel straight ahead with the locking fixture to set the LH, RH and sum toe.
Pro Mechanic
Factoid (04-20-2021)
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
When overhauling my steering box, I learned that the box must be in the dead center position to adjust.
That should hold true when doing an alignment as well. If the wheel is really off center, the rag joint can be clocked.
Got some feedback from my local car club and there’s a recommended place right here in town. Bring my own specs? What specs is that?
