Floor Jack For The Trunk?
I had a front flat (first flat I've ever had in all the years I've owned it) and had the misfortune of trying to use the original car jack (1958). Little room and hard to find a safe spot to grab for the jack. It was in nice weather on asphalt. I can only imagine if it was raining and/or uneven surface.
A floor jack saved the day in seconds and no need for prayers.
Does anyone carry a small hydrolic in their trunk? I see some low profile jacks that weigh 30 lbs.
Received 2,170 Likes
2015 C2 of the Year Finalist
Dan
The following 3 users liked this post by mike coletta:
I bet many would be surprised at how few even know how to properly use a scissor jack.
I saw one guy roll his car right off the jack trying to loosen the lug nuts on a left rear tire with the wheel airborne instead of on the ground. And then apparently didn't have his e-brake set and no wheel chocks.
Having said that there are almost no areas near me now where I would feel safe jacking up a car beside the road on ANY kind of jack. Distracted, aggressive and illegal drivers will run you over here and may not even slow down or stop.
I have an original 63 jack, (price one of those) and, under the right circumstances. Say, stuck in a zombie apocalypse with a flat tire, I would use it without reservation or fear of harming it.
Tether Man
Received 2,049 Likes
2019 C1 of Year Finalist (appearance mods)
If I felt the need to have a floor jack on a trip........
I have one very similar to this, (16 lbs.) I use it on my cross support to lift the front or rear of my Corvettes.
https://smile.amazon.com/Pro-LifT-F-...750811&sr=8-10
16lbs, pretty light!
That fits under a C1?
This would be cool if you know they would last.
Desert Nomad (04-20-2021)
Tether Man
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
I bought a compact floor jack from Blackjack years ago at Wallyworld for about 15 bucks and it's small enough to fit in a C1 Trunk. I grab mine all the time because it's light and grabbable in my garage. Working great for 10 years now.
looks something like this one, .....
Just saw one of these which I'm looking into.....the height of laziness!!!
Received 3,053 Likes
C1 of Year Finalist (performance mods) 2019
This. And a couple of pieces of 2x4 wood. Compact and will get the car in the air without damage. As others have said, break the lug nuts loose when the tire is on the ground and make sure you have a working emergency brake set.
I too have road side assistance but there are times you are in the middle of nowhere with no phone reception and that is when you need to change a tire yourself.
I have a small hydraulic scissors jack in a plastic carrying case in the trunk, I have only used it once and it worked great and was very secure, I also have the original jack and handle but the hydraulic jack is quicker and easier to use.
Bill
Bill
Received 3,446 Likes
Helped a friend with his '63 recently and he had the original jack and I had a generic scissor jack of recent manufacture that looked similar. The original '63 jack was about 10 times better...smoother, faster, more powerful, and plenty stable. We were on concrete. It cradled the frame rail perfectly. Those things are built for rough service, regardless of the prices they now bring. We used it on some other cars that needed tire work as well and did it no harm....not even a scratch.
