[C2] Another choke question
Old 03-13-2021, 09:46 AM
davekp78
davekp78's Avatar
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Also, suggest you ditch the teflon tape on the fuel line fittings.
old60c1 (03-14-2021)
Old 03-13-2021, 11:56 AM
SJW
SJW's Avatar
Received 1,401 Likes on 923 Posts
If you don't have firearm solvent on hand, and the gunk appears to be carbon-based, consider trying a soak in brake fluid. Clean it up well to remove any fluid residue before reassembling. Burning DOT3 will generate some nasty smoke.
Live well,
SJW
Old 03-13-2021, 06:51 PM
C2search
C2search's Avatar
Default 1964 327 300hp AFB 3721SB carb
I have got the choke piston sliding nicely in the bore, reassembled and installed. 👍🏻
However....
The car starts with choke closed and on high idle. When I try to kick it down to warm idle it doesn’t. I have attached some pictures of my linkage. Can someone tell me if everything looks right or if there might be an adjustment required?
(Be gentle. Rookie here)
I wasn’t sure if this should be a new thread
The circled part (fast idle cam?) does not kick down after warming up. I can manually pull the throttle lever and disengage it, but as soon as I accelerate, it sticks again.
This (lockout dog?) does not seem to do anything. It is loosey goosey without engaging anything. Is this normal?
Old 03-13-2021, 07:38 PM
65GGvert
65GGvert's Avatar
Received 3,231 Likes on 2,309 Posts
In your photo with the yellow circle, the fast idle screw is all the way off the cam. If it's still idling fast, maybe your slow idle is set too high. If, on the other hand, the screw is not normally dropping the fast idle cam, try rotating the choke more toward lean. Also check your piston movement from time to time. As I said earlier, mine would still sometimes bind after warmup until I sanded it a little.
C2search (03-14-2021)
Old 03-14-2021, 11:56 AM
C2search
C2search's Avatar
The circled picture is when I manually pull the throttle cable and move the cam to drop the idle down to normal. It will not move to low idle by “kicking it down”.
Once I manually get it on low idle, as soon as I press on the accelerator it sticks back on fast idle (Green arrow).
I still don’t know what the other cam does (Yellow arrow).
I hope I’m explaining this correctly.
The choke piston still seems free and working correctly.
Thanks!
This is when I manually move it off fast idle. It will not kick down on it’s own after warming up.
Green arrow: After warming up, as soon as I press the accelerator it sticks back on high idle. Yellow arrow: This cam doesn’t seem to do anything. It just flops around (??)
Old 03-14-2021, 11:59 AM
SJW
SJW's Avatar
It sounds like the choke is adjusted too tight. Try loosening it up.
Live well,
SJW
Old 03-14-2021, 12:02 PM
C2search
C2search's Avatar
Live well,
SJW
I will try that. Thank you
Old 03-14-2021, 12:09 PM
C2search
C2search's Avatar
Live well,
SJW
BTW - is there an adjustment on the circled screw I need to look at?
Is there an adjustment on the circled screw?
Old 03-14-2021, 01:05 PM
65GGvert
65GGvert's Avatar
The farther that adjustment is run in (clockwise), the faster your fast idle will be at all positions on the cam. I would adjust the choke to be fully off as the car warms up, and then adjust the fast idle where I wanted it to be on a cold start.
Old 03-14-2021, 03:04 PM
rowingone
rowingone's Avatar
I would replace the thermostatic spring as well . .they tire with age and use
Old 03-14-2021, 05:17 PM
C2search
C2search's Avatar
Makes sense. I’ll get one with my next order.
Old 03-15-2021, 08:05 PM
C2search
C2search's Avatar
Default Success!
The choke piston is now moving freely.
I adjusted the choke a little leaner and everything seems to be working great now👍🏻
I took the car for a quick trip around the neighborhood and everything seems to operate correctly and the car is running really good!
Thanks to everyone that took the time to chime in and assist me with this! ⭐️ ⭐️⭐️⭐️⭐️
Hopefully I’ll gain enough knowledge to pay it forward one day.
Quick Reply: [C2] Another choke question
