[C2] Accelerator rod hitting air cleaner base
I recently purchased a 66 with a replacement small block. It has a Holley carb and Eldebrock censuses intake. Engine runs fine but it doesn’t feel like power output at WOT is what it should be. I noticed today the accelerator rod is hitting bottom of air cleaner and preventing linkage from opening all the way. You can see where the base is rubbing the rod in first pic. I have seen suggestions to use a spacer to gain clearance. Anyone have success using them? I have no idea if this is correct setup so maybe I need a different rod?
Received 6,978 Likes
2015 C2 of Year Finalist
Install the rod correctly should help
Here's you another one:
Received 5,581 Likes
Your rod seems to be entering from the wrong side...so to speak. Easy fix though!
Received 3,050 Likes
C1 of Year Finalist (performance mods) 2019
BTW, the 350/365 for 1965 used a different accelerator linkage than the 250/300 h.p. engines. Don’t know about 1966 but worth checking.
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
Man, I love those easy fixes!!!!
