hood clearance 1961 corvette
I put a new edlebrock avs carb on a friends small block 61 vette with edlebrock performer intake manifold. I had to use a 3/4 inch spacer under the air cleaner base to clear the electric choke. the problem is it is rubbing the bottom of the hood. anyone know of a air cleaner made to fit this carb and car? Edlebrock has a triangle shaped one it says it clears electric chokes but its expensive I hate to buy it if it won't clear.
What air cleaner does the car have now? The stock type, or some after market one?
The stock cleaner is pretty low profile, and if the Edelbrock carb needs the larger air cleaner base hole like Holley, you can use a ~'65-'67 Pontiac base/air cleaner, which looks just like stock C1 cleaner.
Doug
Doug
59BlueSilver (10-03-2020)
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
Corvette box stores have low profile air cleaners.....I bought one that was very stock looking that I used on my Edelbrock Performer intake......61 Corvette
Might want to check this out....
https://www.corvetteforum.com/forums...r-cleaner.html
I also added a phenolic spacer, but I don't recall the exact height of the spacer I used (1/4" - 1/2" ???).
I used a 1 5/8"drop base with a WIX 46037 element which is 2 5/8" high and a Mr. Gasket nearly flat top air cleaner lid. That setup gives me one full inch of air flow above the airhorn. The only thing I had to do was dimple the base a little bit to clear the choke cover housing.
I have about 5/8" clearance at the narrowest point between the air cleaner and the hood.
Loren Smith (12-06-2020)
2022 C2 of the Year Finalist - Modified
C2 of Year Finalist (track prepared) 2019
2017 C2 of Year Finalist
2015 C2 of Year Finalist
Put an L88 Hood on this '61 Vette....
Will get the Clearance & hot looks....
Did that on my '62, back in the day...
'62 Vette with L88 Hood.....
