[C2] 65 L76 Spark Plug Question
I have a 65 L76. I read previous posts on the best spark plug. Seems like most like the R45 over the R43s. For an L76, do I need the R45 or R45S? I read a post the plugs sat a little lower in the high compression 63s and thus you wanted the standard R45. Is that the case for the 65?
Thanks in advance!!!!!!!!
Popular Reply
08-15-2020, 08:13 AM
Received 1,974 Likes
All C2 327s were equipped with AC44 plugs. These were non-resistor types and over the years experienced owners found that the one heat range hotter AC45 was less prone to foul and is best of normal road driving including high speed freeway cruising. The AC 45 is no longer available, only the resistor type R45.
If you don't "have" to use AC plugs, like for NCRS judging, the NGK B4 and Denso W-14U are non-resistor types equivalent to the old AC45.
Duke
Duke
Received 6,982 Likes
2015 C2 of Year Finalist
What’s in there now? Is there something wrong that you need to change
Received 1,748 Likes
2018 C1 of Year Finalist
The "S" refers to "extended tip". The non "S" plug (43,44,45) was the recommended plug for the L 76. The key regarding what heat range to employ is going to vary depending on a lot of factors, not the least of which is how you drive your car. The coloration of the plug will be the final arbiter on what plug is best for you.
dplotkin (09-12-2023)
The "S" should be fine. But if you are very concerned........ pull them and check the gap after cranking over the engine with the starter a few times.
Larry
EDIT: My 1967 327/350 runs AC 45 and has no issues. I never required the "S" tip. My engine and yours should have similar pistons and heads (if your engine is original as mine is).
Larry
L76_Cpar (08-15-2020)
Duke
Duke
The following 6 users liked this post by SWCDuke:
ghostrider20 (08-19-2020),
kingwoodvette (09-12-2023),
L76_Cpar (08-15-2020),
mblake101 (04-21-2024),
oldjeeps4me (09-12-2023),
and 1 others liked this post.
Duke
Duke
The AC 44 and AC 45 (and perhaps a few others) are available in reproduction. They appear to be well made and look identical to original. Probably some third party contracting with one of the manufacturers still used by AC to make the retro plugs. They are a bit pricey at about $60 a box of eight. With a bit of patience, original NOS can be purchased for the same money or perhaps even a bit less.
As you are aware, with the driving we do with these old cars and the unleaded gas many of us use, a new set of plugs will go 5-10 years. So the $$ are not so critical/important over this lifespan.
Larry
Duke:
Larry
Larry
It idles rough so my first thought was plugs. I just pulled two plugs this morning and they are AC R45's. To my surprise, they were not bad. No oil or abnormal discoloration or wear on the first two so that gives me hope. I thought I would next check the timing. If it is the distributor, I will have some studying to do; I know nothing about points (I had a C3 with TI so never had to deal with points)....
Thanks again, I appreciate the thoughts...
zim64 (09-13-2023)
Points are easy............don't worry. Dwell should be 30 degrees +/- 2 degrees. Hopefully you have or can borrow a dwell meter. Once set they will go 12,000 to 20,000 miles. Just be sure they have a little dab of grease on the points rubbing block and on the points fiber cam follower.
With the 327/365 HP engine you will likely not be able to set initial timing before the engine will die. So you will have to rev it up (when warm) to 3500-4000 RPM so see when the mechanical advance quits advancing, and then set it to 36-38 degrees at that point. The vacuum can should be disconnected and the rubber vacuum hose plugged during this time. Note your RPM and what the mechanical advance is at idle............for future reference. Then reconnect the vac can and see if it advances the timing another 12-16 degrees. I believe the vac can should be a GM 236 which provides 16 degrees of vacuum advance at idle.
But regarding the rough idle. Your engine will idle a bit rough with the 30-30 cam. But if car sat up like you say, chances are the carb needs a cleaning and tune up.
Lastly, don't forget to check and reset the solid lifters.
Larry
Larry
Buy a old Snap On MT460 meter. this will help to trouble shoot why your engine is not running correct. this with a snap on timing gun along with a vacuum gauge you should be able to dial in your car without throwing parts at it in hopes of fixing it. This one on Ebay is grossly over priced though
https://www.ebay.com/itm/Vintage-Sna...kAAOSwHv1extpi
365 HP and Vacuum advances
Larry
Larry
zim64 (09-13-2023)
Duke
Duke
