Carburetor air flow
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Carburetor air flow
I’m working on a 67 390hp after a carb rebuild and it idles well but after making final adjustments and it’s warmed up, I noticed a drop in idle speed as soon as I installed the air cleaner. I’ve tinkered around with the idle mixture screws and it doesn’t make any difference, it still rises or drops. Stock carb and new filter assembly. It will drop or raise 100 rpms when installing or removing the lid. The car runs well at driving speed but I’m wondering if it’s starving for air then or when it’s at full throttle? Any suggestions?
Might be a PVC issue since installing the air cleaner causes the air supply line to the valve cover to pull filtered air from within the enclosed filter/carb inlet area rather than the open atmosphere. But not sure how it could make that much difference at idle.
It's very odd. I can hear the idle difference immediately either way. I thought about the PCV also, so I'll look into that today.
Received 6,547 Likes
C2 of Year Finalist (track prepared) 2019
If you can, put the lid on the air cleaner first and then adjust the idle mixture.
csherman (06-02-2020)
Putting the lid on forces air to pass through the filter element and that slightly restricts air flow. That causes a mild choking effect and your idle mixture is almost certainly a little richer.
I drove it to get it warmed up today, so I have the mixture screws at 1 full turn. I tired them at 3/4 turn but the engine didn’t like that and while I was doing that, I saw coolant dripping from the top radiator hose, so that shut me down on the carburetor. I had to repair the hose leak after it cooled down. Back on the carb tomorrow.
That doesn’t sound to be on the rich side so still a bit of mystery. If you have timing dialed back it might be that the slight amount of rpm loss When the air cleaner lid is installed is being further accentuated by a lack of timing causing it to drop further.
Received 2,143 Likes
2015 C2 of the Year Finalist
Dan
Do you have a stock air cleaner? If not Is it touching your throttle linkage? Is your air filter extremely dirty or restrictive?
Received 1,974 Likes
Does the engine have the OE air cleaner? I think it's an open element type with a 14" x 3" element. The air flow at idle is so low that it would require very sensitive lab equipment to measure the pressure drop across the filter. Something else is going on.
Duke
Duke
Just a guess but I once owned a 65 396 car that had an incorrect aftermarket Holley carburetor on it. The float bowl vent tubes were cut straight across instead of at an angle and both touched the air cleaner lid. The same issue occurred. It ran richer with the lid installed. The air cleaner lid is at an angle so the tubes weren't totally sealed but it still had an effect. There were C shaped marks on the underside of the air cleaner lid.
Original air cleaner base. Original carb. Nothing is touching linkage. Vent tubes are not cut, they have correct angle. Filter is new. It makes no difference if the whole assembly is removed or just the lid. Too many things going on today to get back at it.
Fir st thing I learned at GM training center in1962 in carb class was fuel air ratio.For every gal. of gas you need 10,000 ga. of air. Very same thing happened with my 67 427 390 when I first bought it. Had a clean looking paper air filter and RPM,S would drop when cover was pup on. Bought a high performance S T P air filter and that fixed it. Started my own auto shop in 1965 and took many week long classes at GM center, best training you can get, and all free.
I finally got back on it. I changed the pcv and the air cleaner. It is a little better but I haven’t had the time to drive it yet. Too many priorities and bad weather.
