[C2] Update on my restoration of my brothers 67 L71
Just wanted to touch base and give you all an update and maybe get some more helpful knowledge. I've got the body finished and 3 coats of urethane primer, working under the dash, installing insulation prepping to get wiring harness installed. I did get a new harness after trying to restore the original but not feeling comfortable using it. Gonna be finishing the frame so I can put them together again. I incl some recent pics. Any guidance is appreciated.
Blacked out engine bay
The following 18 users liked this post by retirementtoy:
63silver (05-11-2022),
65-L78 (11-11-2020),
Art17 (06-25-2021),
badhabit_wb (06-25-2021),
capevettes (05-14-2020),
and 13 others liked this post.
It looks very nice, you are doing great work.
Looking forward to more pictures.
Aflyer
Aflyer
The following 3 users liked this post by Aflyer:
Looking good. Wish I had your paint talent. I guess I missed your first post. Sorry to hear about your brother. I’m sure he would be proud of all the work you have done. I sent my brother’s out for the paint and body. Keep us updated as you go along.
The following 3 users liked this post by elwood13:
Received 5,011 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Good progress! It's a big boost when you turn the corner from taking things apart, to putting them back together again!
The following 2 users liked this post by Railroadman:
ptjsk (06-21-2021),
retirementtoy (09-18-2020)
Ain't that the truth. It's also good to have it one color again. I have been putting things together before painting because most of this stuff my brother took apart so I didn't get to see how it worked but im getting there. I hope to have it together by July or August.
hcallaway (09-01-2020)
The following 3 users liked this post by Railroadman:
Gettin there
Just another update. Got the wiring harness installed everything under the dash is complete installed heater, windshield wiper/washer motor, master cylinder and radiator core support installed. And on the chassis installed starter new tranny to bell housing bolts and finished the tranny mounts.
The following 5 users liked this post by retirementtoy:
elwood13 (09-18-2020),
gowenfast (08-26-2020),
morly1963 (08-26-2020),
ptjsk (06-21-2021),
Westlotorn (09-20-2020)
Great progress! What did you go with for the new wiring harness?
Beautiful. Sting Rays almost look better in primer than in paint.
retirementtoy (09-28-2020)
September update.
Well it ain't done. Have had some hip problems and m thyroid removed. The body is real close to being ready for paint so I've been working on the chassis, it's mostly done, I've got to check all points for cotter pins and brake lines are all good, then I need to install the spare tire case and get the alignment as close as possible. I'm hoping to set the body on in a week or two, wish me luck.
The following 9 users liked this post by retirementtoy:
frankturbo (09-18-2020),
gjhinc (09-18-2020),
norway66 (09-21-2020),
and 4 others liked this post.
You did a great job. Wish I was that far along on mine.
I'm sure getting back to work on the car helps your morale after dealing with the health issues. You made the right call on replacing the wiring. I keep waffling on whether to get a new original-style set for the '64, or the upgraded type which has more safety features, modern fuses etc, but requires adaptation on a couple items when i go to put it in.
I'm sure getting back to work on the car helps morale your after dealing with the health issues. You made the right call on replacing the wiring. I keep waffling on whether to get a new original-style set for the '64, or the upgraded type which has more safety features, modern fuses etc, but requires adaptation on a couple items when i go to put it in.
Glad yours went in with no problems. You will sleep easier knowing the car does not have 50+ year old wiring.
Bluestripe67 (11-11-2020)
retirementtoy (09-21-2020)
November update
Well the body and frame are reunited. Oct 17 I had a couple folks from our local NCRS group and some of my regular buddies came over and helped put things back together. Everyone was great help. Here's a couple of picks of the day. I'm still working steady on it but it always takes longer than you think.
The following 10 users liked this post by retirementtoy:
elwood13 (11-11-2020),
Factoid (11-11-2020),
got2hav1 (06-21-2021),
leif.anderson93 (11-11-2020),
and 5 others liked this post.
