Corvette Forum
Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-25-2002, 05:13 PM   #21
JohnZ
CF Senior Member
Support Corvetteforum!
Default Re: First year for the 396? (Ironcross)
The 1969 L-78 (396/375) Camaro used the 3863143 cam (as did the Camaro 427/425hp COPO and L-89 engines); the Camaro 325hp and 350hp 396's used two different hydraulic cams - 3874872 (325hp) and 3883986 (350hp).
The L-78 also used the 9840 iron heads, and the L-89 used the 842 aluminum heads; both had 2.19" intake valves, and the iron heads had 1.72" exhausts while the aluminum heads had 1.84" exhausts. The 325hp and 350hp 396's used the 063 oval-port heads, with 290 heads very late in the model year.
All '69 Camaro 396's and 427's used the same exhaust manifolds - 6178 and 9879 - all were drilled/tapped for A.I.R. fittings, and all Camaro solid-lifter BB's used casting #3933163 aluminum high-rise intake, with one large hole and a center divider. :thumbs:
JohnZ is offline   Reply With Quote
Old 11-26-2002, 08:19 AM   #22
396 RAT
CF Senior Member
396 RAT's Avatar
Default Re: First year for the 396? (JohnZ)
John, could the 67 396 safely be bored to 427?
From what I have read the 65 396 block was the only one.
Making it not the same. But there are so few around,
nothing is in stone. Mainly speculation.
Many books say the engines were "virtually" the same.
And looking at the cam specs I posted earlier,
what do you think? I have read they toned the cam down
for 66, but am not a cam guru. The 65 cam has not been available
since the early 70's. My car got a STD 66-67 cam in 76.
Not many 396 threads either, still plenty of confusion on the subject it seems.
:lol:
Red man needs to show up, as he researched the heck out of this.
396 RAT is offline   Reply With Quote
Old 11-26-2002, 09:03 AM   #23
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
Default Re: First year for the 396? (396 RAT)
i have bored several original 65 corvette 396 to 4.250 back in the 60s but i never tried to bore them .125 over 4.250 which the 427 blocks will take. the 396 used in chevelles,camaros will not take a 4.250 bore as i also did that and the cly. cracked. the 65 corvette cam was different than the 66 and 144 was the # and the valve setting was .020and .024 in the 1965 interim shop manual. and we did run them as close a .012 and .018:chevy
clem zahrobsky is offline   Reply With Quote
Old 11-26-2002, 09:15 AM   #24
396 RAT
CF Senior Member
396 RAT's Avatar
Default Re: First year for the 396? (clem zahrobsky)
Thanks for the info.
Its appreciated.
What should I adjust my valves to?
My book says the same for 65,
but my engine has the 66-67 cam.
And just know in time this thread will
show up all over again.
And I will get :nono:
:lol: :lol: :lol: :lol:
So in the future is it safe to say the
Block, cam, intake, heads, exhaust manifolds, ignition,
carb were diferent?
Or will I get :smash: ?
[Modified by 396 RAT, 8:43 AM 11/26/2002]
Old 11-26-2002, 09:50 AM   #25
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
i have run the 143 cam at .024/.028 but also have run it .020/.024. the low end is smoother at .024/.028 :chevy
Old 11-26-2002, 07:35 PM   #26
Revette
CF Senior Member
Revette's Avatar
"396 Rat, how could that be? That car used the same 1/2 shafts as the mighty 427?"
I don't know....I just watched that car self-destruct at the christmas tree.
Revette is offline   Reply With Quote
Old 11-26-2002, 10:58 PM   #27
396 RAT
CF Senior Member
396 RAT's Avatar
Default Re: First year for the 396? (Revette)
Just being cynical....
Old 11-28-2002, 08:49 PM   #28
Tom DeWitt
Premium Supporting Vendor
Tom DeWitt's Avatar
Did they carry over the 65-396 aluminum radiator 3007436 to camaro too?
Tom DeWitt is offline   Reply With Quote
Old 11-28-2002, 09:04 PM   #29
67HEAVEN
CF Senior Member
67HEAVEN's Avatar
Default Re: First year for the 396? (Tom DeWitt)
:lol: :thumbs:
67HEAVEN is offline   Reply With Quote
Old 11-29-2002, 12:13 PM   #30
Ironcross
CF Senior Member
Ironcross's Avatar
Default Re: First year for the 396? (67HEAVEN)
No, no aluminum radiators in the early Camaro line. It would have been nice however. None of mine were so equiped and they are all big block cars. :thumbs: :flag :thumbs:
Ironcross is offline   Reply With Quote
Reload this Page First year for the 396?
Tags
1965, 396, 3963143, 396375, cam, corvette, cu, engine, firts, gm, offer, spec, year, years
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help from in depth C1, C2 members on year indentification. zphantom C1 & C2 Corvettes 19 11-29-2003 07:57 PM
Sure, AFTER I start my own... JohnZ's old Grand Sport is on eBay again. Mecom Racer C1 & C2 Corvettes 54 11-11-2003 01:29 PM
No respect... 396 RAT C1 & C2 Corvettes 43 09-01-2003 09:07 AM
Here are the details for my 396 Stroker. Hammer C4 Tech/Performance 20 03-07-2003 11:14 AM
Want to build a C4 for top end.... NosLaser C4 Tech/Performance 46 03-16-2002 11:33 PM
New Dyno Numbers for the 396 With the Superam 89vette C4 Tech/Performance 29 11-04-2001 02:57 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
