Control Arm Shaft Removal
Hi everyone !
I'm trying to remove the shafts from the upper and lower control arms to replace the bushings on my 64 convertible.
I know the bushings are pressed in, so the shafts have to be removed first.
How the heck do I remove the shafts so I can replace the bushings ?
I'm sure the answer is in the forum someplace, but, after looking for it, for a while, I give up.
Thank you !
Dom
Thank you !
Dom
If you have a service manual it has instruction, but those probably use a press.
Another way is to use a torch (plumbers propane or acetylene) and burn the rubber out. Then the shaft and inner bushing will come out, then use a hammer and chisel to collapse the outer bushing.
I used the air chisel method described in Lars' suspension rebuild paper and it worked exactly as described. It took about 15 minutes to remove all 8 bushings. You can find his paper via a google search for "Lars suspension rebuild paper". I believe that is an older version of the paper but the bushing removal portion is valid.
Received 1,529 Likes
C2 of Year Finalist (appearance mods) 2019
take a look at this video, starting about 2Min 25 sec into the video: https://www.youtube.com/watch?v=aT2jQUB1nIQ
