Is it the fuel pump?
It's a 67, 327/300, automatic and air conditioning. I tried to crank it yesterday with no luck; the carb (Holley Model 3810) isn't squirting any fuel in the venturi. My first thought was that a carb float may be stuck, so I gave it a few sharp rps, but no luck Next I checked the fuel filter, which was clean. I can only conclude a bad fuel pump.
Accelerator pumps don't usually suddenly go bad, Any ideas?
Received 6,980 Likes
2015 C2 of Year Finalist
what fuel filter did you check? sounds dumb but did you double check there is gas in the tank
Pull the line going to the pump and see if you get fuel. It may have a hole somewhere and sucking air. If its good, check fuel pump arm and see if it came loose. If its good pull line after pump and see if you get anything. If you dont I would think the pump went. Im saying this because you did check for gas when you checked the filter?
