[C1] 57 dual quads question
Old 01-07-2019, 06:32 PM
Mailbu Beach
Mailbu Beach's Avatar
Default 57 dual quads question
1299 airhorns
what is the difference in application between an 049 main body and a 1049 main body?
joe
Old 01-07-2019, 07:56 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,084 Likes on 4,737 Posts
Army
For the 57 year the info I have says they are interchangeable, so I don't know that there is a significant difference...
Old 01-07-2019, 08:02 PM
Mailbu Beach
thanks!
I wasnt sure if 049 were production line or if 1049 were period over the counter replacement or if 049 was front and 1049 was rear.
Old 01-07-2019, 08:04 PM
L78racer
L78racer's Avatar
245 and 270 hp all have those main bodies. 270 hp main bodies differ but are same number(s).
Old 01-07-2019, 08:14 PM
Frankie the Fink
Army
And if its a very early 57, they used 56 carbs and only the 049 bodies...
The '56 carbs have the idle air bypass screw in the base as shown...
Old 01-07-2019, 10:02 PM
tgtexas02
tgtexas02's Avatar
Thinking all 0-049 and 0-1049 are the same and according to 58-60 Tech Info Manual & Judging Guide-both are correct. The only difference I know of between the 245 and 270 main bodies would be the counter weights and the main nozzle on the primary side. Not sure I really get this last part but the 270 you can look into the nozzle and on the 245 you cannot see the tube--I don't get this at all. On the air-horn, it may or may not be stamped ahead of "6-1299" casting with front "1161' or rear "1296". And, the prior to 61 front bases will not be tapped for vac.
Old 01-08-2019, 04:31 AM
Frankie the Fink
Army
The 270 hp carb bodies have primary nozzles cut at a 45* angle as show in this picture in the green circles even though the 245 and 270 lid numbers are 6-1299 in both cases... The counterweights are smaller on the 270hp carb.so the rear air valves can move with the lower vacuum of the solid lifter engine...
I "think" I recall that the spring under the vacuumeter piston that rides off the bottom of the metering rod "T" bar had different tension for the same reason, but I haven't confirmed that...
The 61 bases for the RPO-242 PCV option had tapped bases, I don't know if non RPO carbs for the same year did or not...
Old 01-08-2019, 10:41 AM
tgtexas02
tgtexas02's Avatar
I get the angled nozzle on the 270 HP but I still don't get the "cannot see the tube" for 245 HP in NCRS guide. Basically, what do the tubes look like on a 245 HP setup? I have a set that has original "L8" brass tag date "2627S" which is 245 HP and the air-horn nozzles look just like the 270 HP.
Old 01-08-2019, 11:06 AM
Frankie the Fink
Army
That's just a bad description I think..... I take it to mean that you can't look down into the straight, vertically cut off nozzles (tubes) as you can with the angle cut 270hp primaries. I wouldn't dwell on it. The NCRS documents are far from free of mistakes and vague statements...
Old 01-10-2019, 08:43 PM
Mailbu Beach
Great detail...Thanks!
Old 01-11-2019, 03:15 AM
tgtexas02
tgtexas02's Avatar
You might also note that the 1299 rear is drilled for choke shaft while the 1299 front will not be drilled.
To 57 dual quads question
Quick Reply: [C1] 57 dual quads question
