Muncie Front Nut Wrench
Can anyone tell me what the nut/spanner size is? I have laser cutting done and was going to get one made with my next order.
Welcome to the Corvette Forum, you might want to show us what you're talking about, I'm having difficulty envisioning what you're referring to.
(When you say spanner, you are referring to a wrench aren't you?)
Good luck... GUSTO
Good luck... GUSTO
I think Auto Gear Equipment sells the wrench your looking for.
GUSTO14 (10-07-2018)
Received 1,537 Likes
I made one and the flat to flat dimension on the nut is 1-21/32". The problem is the wrench is only 1/8" thick and must be made from hardened steel to not bend when you torque the nut to GM specs. I bent my homemade one before I finally modified it to get the torque. Haven't tried to heat treat it yet.
Might be easier to order from AutoGear. They are good people.
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
It would probably be easier to just buy one.I got mine MANY years ago from Larry Fischer of D&L Transmission (I don't know where he gets them). http://www.dandltransmission.com/
The wrench I have says VICTORY PERFORMANCE PARTS.
C2andyP (10-07-2018)
Received 1,747 Likes
2018 C1 of Year Finalist
Technically, it is called a gland nut. It retains the front input bearing on the input gear/shaft. The nut is 1-5/8".
Thanks guys, yes wrench not spanner :-) I'm only thinking about making one because I cant find one in the uk and its a bit costly with delivery from US to UK
I bought an Eaton posi unit for a guy in New Zealand a few years ago then shipped it to him for costs.
Just a thought. If this is a complete rebuild of your transmission, you might want to go the extra step and order a steel mid plate that houses the main output bearing. The OEM plate is aluminum and can be prone to leaking over time. Larry at D & L transmissions carries them and they aren't that much money. Just another preventative step to consider.
Received 1,126 Likes
Here are the dimensions to my wrench/spanner. This was traced on 8 1/2 x 11" paper on a diagonal.
I use a large Channel-lock plier to remove the nut and the tool to install the new one.
Joe
Joe
Yep, Left hand threads. Keeps it from backing off when the input shaft turns.
