Cold start a C2 (and probably others)
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
One pump, choke sets, and fires right up. We have had about 50+ days over 100* this summer. Nice and hot in the garage like Frankies in Florida.
Received 2,146 Likes
2015 C2 of the Year Finalist
Whenever this old fuel bowl evaporation thing comes up I repeat my experience with dozens of carbs I've rebuilt....
I install them bone dry and the cars start within 5-7 seconds of cranking and pumping the gas....some might take a tad longer but very rarely...
That's AFBs, WCFBs and Q-jets...
Since initial light off has little to do with the choke what do you say accounts for all of the various experiences everyone has?
Dan
I have many friends who report the same experience. Its the variability between cars and carbs that get me. My AFB's are the best running but most difficult starting if idle for 2 or more weeks. My 4GC will start, no choke, as if it had no idea of ambient temperature.
Dan
Dan
I had several experiences of vapor lock two summers ago.....I installed the same model carb which I had freshly rebuilt last November and no more vapor lock no matter how I treat the car... Strange.
My AFB always ran rich after several rebuilds and would heat soak on shutoff and flood. I tried the FI intake gaskets to no avail.
I know they can be set up to work well but the Holley swap was my magic bullet. The small Holley on my 302 Ford is also a winner.
Dan
Dan
I don't run a choke on mine, plate is removed. If it has been less than a week, I don't pump the gas, it fires as soon as the first piston rolls over TDC. If it has been over a week, three pumps, and same.
Received 1,844 Likes
Also, it alleviates the need to "3-pedal" at the stop signs on the hills to reach the first light. My "line lock" also helps here for the stop sign at the top of the hill.
Oh yeah, I have had some really cold-blooded cars in my time. But my 63 isn't one of them. It fires immediately and settles into a smooth idle. If it is really cold out, I'll have to lightly blip the throttle to prevent it from loading up. I'm running a stock ignition system with a Holley 650 double pump on a performer intake.I picked up a C3B-X intake at a swap meet last year, but haven't had time to install yet.
#34
Here is how I added a "fast idle" to my milled Holley. Note that while it doesn't really show, the ignition shield is in place and hides all of this.
Solonoid is mounted to the side of the windshield wiper motor assembly. I cut down the spring to reduce the tension and there is a thermal switch sandwiched between two resistors to prevent overheating if I forget to shut it off.
Lamp chain is used as the interconnecting link. The ***** allow for a quick, easy "pert near."
A couple nuts/screw adjustment takes care of the "fine tuning."
The chain connects to the linkage at the joint.
And a switch under the dash allows me to manually toggle it (along with my line lock and rear vent). The red **** behind the parking brake is a Tilton 7-position, brake proportioning valve for the rear drums.
#35
Received 2,371 Likes
One caution with vented tank stored oxygenated fuel is water absorption in the ethanol along with condensation, and water separation and settling in the bottom of the tank. The fuel pump delivers mixed water from the bottom of the tank, rather than quality fuel. You can pump watered down fuel into the carb & intake for a long time without engine fire. Static engine operation without road motion to mix the ethanol just adds to the water separation problem. Aircraft have tank drains to clear the water in the wing tanks, part of the pre-flight checklist. Operating the engine closer to empty than what is advised with modern FI will help to burn through the poor fuel.
#36
Actually, if my 67 has sat for a couple weeks or more, I do NOT want it to fire up immediately on first crank. Instead I will let it crank with no throttle shots in a couple of 5 second bursts until the oil pressure comes up tp 30 psi or so.
THEN a couple pumps on the gas pedal and it fires right up! No choke on this one / just hold 1500 rpm or so for about 30 seconds-and good to go cold.
When warm fires first time every time.
#37
But I'd hate to do it at -10.
Dan
#38
Why would you be doing "hole shots" with a cold engine anyway?
Seems like that might be hard on equipment whether you had a choke and/or heated intake?
Lot's of drivers have never had the experience of driving a car without FI, PS, PB, AC, automatic transmission and other features that are now stand equipment on almost all new cars until they buy an old collectible. Even if everything works as designed on an old car, newb drivers tend to think there is something wrong with the car.
The following 2 users liked this post by MikeM:
Brian VH McHale (09-18-2018),
tuxnharley (09-18-2018)
#39
64's Rock!
This has been an informative read for me. I've been pumping before cranking on a cold engine, but hadn't been waiting before cranking. Tried that yesterday and wow! It fired up instantly. Thanks for the tip!
#40
