[C2] Muncie shifter adjustment
'66 Muncie has suddenly begun popping out of 3rd gear under light load or deceleration. Decided to check the linkage adjustment and made up a 0.646 x 3 inch tool from 1/8 aluminum per the manual. Slid under car and realized that I can barely see the adjustment slot let alone get the tool in there.
Can the tool be inserted with the transmission in the car? Can it be done from above with the shifter stud rubber boot removed?
Thanks,
Ralph
Thanks,
Ralph
Inserting tool
just readjusted my resently installed hurst competition shifter.You can only install from under he car.
you need a light to see adjustment slot. I used a long nose plyer to help install the adjustment tool.
If you need a bit more room you can disconnect a shift rod from the trans . Not the shifter.
fred
fred
After38Years (08-17-2018)
Thanks,
Ralph
Thanks,
Ralph
I did the adjustment recently with a helping hand from a friend. He was under the car and I was inside in the driver seat. It was easy to feel on the shifter lever on the left-right movement when the 1-2, 3-4 and reverse shifters were lined up. Has functioned flawlessly after the adjustment.
The following 2 users liked this post by 65 Pro Vette:
After38Years (08-17-2018),
eyedocs96 (08-18-2018)
A Hurst shifter has stops on 2nd and 3rd gear positions and if misadjusted can prevent full engagement of the gear and popping out. A Muncie doesn't have an adjustable stop for these gear positions so shifter adjustment is usually not a cause of the transmission popping out of gear. If it's that misadjusted you probably can't shift it at all due to misalignment of the neutral gate. Your description sounds like classic symptoms of weak/worn - slider/gear engagement teeth that probably will need to be addressed by a re-build. A bad pilot bushing is another possibility but I believe that more often impacts 4th gear. Just my 2 cents
Received 1,757 Likes
2018 C1 of Year Finalist
I think Dan has hit it on the head. 2nd and 3rd gear synchro units take the most abuse. I, too, don't think adjusting it will make any difference. Time for a rebuild. Once you have it out, do it right and go through the whole unit with new brass rings for all of the forward shifting gears. Also, examine the entire second gear synchro unit and replace it if at all questionable. No sense going back in at another date and repeating the process.
Ralph
Received 1,844 Likes
If you know what the neutral gate is supposed to feel like, and 1-2 lines up with R, have your helper adjust one or the 3-4 rods until the neutral gate is good all the way across..
The only way I'd fiddle with that tool is if I was installing everything from scratch and that would only be to make sure the shifter was centered, fore/aft.
Yes, you can align 1-2, 3-4 on reverse neutral gate. That's what I was saying above.
If you start from scratch and adjust your reverse neutral gate off center, fore/aft, your other gears will be off as well.
Picture for reference and yes, I know it's a BW transmission but same adjustment deal.
But try the easy stuff first - if the 3-4 shifter arm is way off the neutral gate it may not be pushing the slider all the way forward over the 3rd gear engagement teeth. Adjusting the 3-4 shifter arm to where it is marginally adjusted to favor 3rd gear engagement (pulling the transmission lever fully to the rear) but still allows transfer in the neutral gate might gain you a little.
Did they replace any gears or syncro sliders at the time of rebuild? The brass syncro rings only help to engage a gear or upshift/downshift without clashing and they have no effect on kicking out of gear. A typical rebuild usually only includes replacement of the brass rings unless there are complaints at the time of kicking out of gear, which for an experienced rebuilder will then require looking closely at the gear and slider and replacing whichever or both are showing wear. If the gears or sliders were worn and marginal at the time of rebuild - but still holding in gear, they may now have worn beyond the point of no return.
