[C2] Looked at the 67 435hp today
Received 1,126 Likes
I finally got to look at the 67 today.
Are these carburetors correct and does the build sheet look original? Does the underside of the hood look correct?
It has a bad cam, needs a radiator and some TLC under the hood. It also looks like someone made the carb. linkage.
Joe
Joe
The vacuum pods are there which is a good thing but the throttle linkage appears to be converted to mechanical.
just watching.
2015 C2 of Year Finalist
Converted to mechanical secondaries. Cool job on the linkage.
We need to see more of the tank sheet, if there is any. Based on what you are showing of it, there is nothing to indicate it is a copy.
This is what OEM linkage looks like:
plaidside (08-04-2018)
Did a dealer search on the tank sticker, and came back to California which would explain the air injector smog stuff on the sticker, if you run the NCRS report on it should "confirm" the dealer codes "if" the sticker is legitimate.
GUARDIAN CHEVROLET
Dealer Zone:20
Dealer Number:189
Address:800 SOUTH BREA BLVD
City:BREA
State:California
Zipcode:92621
Source Year:1967
GUARDIAN CHEVROLET
Dealer Zone:20
Dealer Number:189
City:BREA
State:California
Zipcode:92621
Source Year:1967
C2 of Year Finalist (stock) 2019
YUP! done that few times over the years on tripower stuff. it works pretty good. MR GASKET used to offer a kit back in the day too do it. if i remember right we did that on my buddys GTO set up.
Received 1,391 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
1971 dated carbs, pins that hold emblems on the hood way too long.
Thanks for all the responses. I am about to get on a cruise ship for two weeks and I will make an offer when I get back.
He wants to get 100K but that ain't going to happen. I will throw out a 65 K offer and see what happens.
Joe
Joe
I saw the consequences twice back in the late '60's and early '70's. 1st was a '69 435 coupe that was totaled (yes totaled) because when the linkage for the "dumpers" stuck wide open the driver stepped on the clutch and let the motor rev till it exploded. The other was a '67 435 convertible that the "dumpers" stuck wide open and the driver was smart enough to shut the key so it only flipped the belts and spit out some coolant.
Received 1,859 Likes
Here's what factory 3x2 carb linkage looks like.
plaidside (08-09-2018)
Don't mean to insult or knock the car, but you asked...
427 emblem studs are way to long and do not have the black gum they are supposed to. Emblems likely repro
The hood insert appears to be a repro
Radiator cap is wrong
Bolt ons are repro
Carb linkage is wrong
All the carbs are wrong (date code should be Year, Month, Week)
Valve cover on passenger side is repro
Oil cap is repro
Intake vac setup is not factory
Bolt ons are repro
Oil cap is repro
Thanks for all the responses. I am on a cruise ship now and when I get home I will shoot him a cash offer and see what happens. He might not know all the things that has been mentioned here but I will enlighten him.
I don't need another car but I would make an exception for this one!
Joe
Joe
