Expert Transmission Help Needed
Something else I forgot to ask, if anyone knows off the top of your head. I will be looking for a new slip yoke for a muncie. Are all ujoint cups for these the same size or did they make different ones for the big block / small block.
Thanks again.
Thanks again.
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Where a difference may occur is with the 71-74 Muncies and later Super T-10s which had the larger 32spline tail shaft.
Vette5311 (07-24-2018)
Well, I've been screwing with, busting knuckles, cussing and fighting old Chevys (started with a babbit beater) and Corvettes for over 55yrs (as well as a few HEMIs, Pontiacs, Olds and Fords). In fact, I do own ONE Ford--------------------------but it's built tough with Chevy stuff!
You are definitely doing right changing the transmission to a Muncie or a later much stronger ST-10. If it has not all ready the big block will twist the course spline tail shaft or the input shaft. The small iron front bearing retainer dates back into the forties, I can only assume GM installed the aluminum front bearing retainer to go with the 1963 aluminum bell housing for 1963.
I would sell it as is, chances are the gears all need to be replaced along with the sliders etc for a proper rebuild.
Post the #'s stamped in the main case just below the WC2832 assembly date and a better picture of the tag attached to the side cover bolt.
The 621 bellhousing you report is probably the original to the car.
Thanks again.
Yes
The Muncie I'm looking at I believe is a 67 but not sure. It has the speedo cable out of the driver side no the passenger side so I believe that makes it a pre 1969 one. It has bolts that hold the shifter arms on the side cover not studs so again I think it is a later one. I will have to do a spline count on the out put and look for a P code for date.
Thanks again.
Thanks again.
Muncies in Chevrolet products were on the LEFT side up through 65, then in 65 they put the speedo fitting on the right side. BUUUUUUUUUUT, some cars, such as Pont GTOs continued to have the speedo fitting on the left side up to about 1970.
Muncies had the shifter levers attached by studs/nuts through 68. In 69-later, the shifter levers were attached with bolts.
Now, with that said, studs/bolts for attaching the shift levers is NOT a guarantee of 68-earlier or 69-later unless it is an unmolested virgin tranny. Over the years I (and other people) have pieced together Muncies from various parts, including using early or later shifter shafts on early or later Muncies.
Received 3,443 Likes
I agree, I think I have a line on a muncie that is a close ratio which would give me about 9.0 total 1st gear, ratio which should be very nice. The only thing is the car has a 4.11 rear which may be a bit to low for comfortable cruising. I looked at a ZT S T-10 which is about the strongest one made of aluminum, but it is only rated at 345 ft/lbs and that is probably not enough for a big block. I have a competition + shifter that I sent to Hurst for a rebuild and then the only other thing I will need is a new slip yoke for the Muncie. I will go through the old T 10 and then put it up for sale to regain my money for this new unexpected venture. Hopefully there is someone out there doing a 63 restoration that will need this old one for it numbers.
Gears
No matter what 4 speed you end up with, they all will give you a 1:1 4th gear. So if your 4.11 is too high winding for you, you may want to swap the rear center section for something more user-friendly. Keep the close ratio for 3.70--4.11, but if you go 3.08-3.36-3.55, a wide ratio Muncie will suit your needs better due to the lower 1st gear ratio that it has.
I will be back there tomorrow
Whichever side the speedo fitting DOES NOT necessarily determine the year model of the transmission.
Out with the old
Green gear
The Muncie has a green plastic driven speedo gear, I believe this is correct for the 4:11 Does anyone know for sure? Hate to try and change it once it's in the car.
#33
Received 1,126 Likes
Joe
Axle-------drive/driven
3.08-------8/18
3.36-------8/20
3.55-------8/21
3.70-------8/22
4.11-------8/24
4.56-------6/20
Duke
PS
ratio__ tire size __drive gr____ driven gr_ teeth__color
2.73__8.15-G70__3895494____3987918_18____brown
3.31__8.45-G70__3924098____3987919_19____natural
3.36__8.15-G70__3924098____3987920_20____blue
3.55__8.15-G70__3924098____3860344_21____red
3.70__8.15-G70__3924097____3860345_22____green
3.70__8.45-____ 3924098____3860344_21____red
3.73__8.15-G70__3924097____3860345_22____green
3.73__F70______ 3924097____3860348_25____orange
4.10__8.15-G70__3924097____3860347_24____yellow
4.11__F70______ 3924097____3860348_25____orange
4.56__8.15-G70__3924097____3860345_22____green*** uses 3890575 adapt
Vette5311 (07-27-2018)
#36
I believe SWCDuke posted this.
Joe
3.08-------8/18
3.36-------8/20
3.55-------8/21
3.70-------8/22
4.11-------8/24
4.56-------6/20
Duke
PS
Joe
3.08-------8/18
3.36-------8/20
3.55-------8/21
3.70-------8/22
4.11-------8/24
4.56-------6/20
Duke
PS
#37
I am a bit confused here. I have read else where green was for the 4:11. (Heartbeat City) I don't know what the number of teeth on the drive gear on the mainshaft are, and I don't really want to remove the tail shaft housing to find out. I realize the tire size will affect this reading but that will be close enough for me. However, getting the wrong color gear will be quite a bit off. According to your post I should have the orange gear if I read it correctly. Thanks
#39
Takes but a minute to pull the driven gear and shine a light into the hole and count the drive gear teeth. Especially sitting on the bench. Probably less than a minute.......
#40
Received 1,859 Likes
Here's everything you need to know about Corvette speedo drive and driven gears.
