62 corvette rear end
Have chance to swap my 411 rear end for a 313 or something close, Would you do to improve ride and fuel economy. never race and drive about 2000 miles a year. I am told gear change is great improvement in both and easy to swap whole unit.
I would go even lower then that, or higher, whatever the correct term is. I have a 306 in my 63 and can cruise down the road a little over 2000 RPM. Not only gas saver but quiter and cooler.
Received 3,777 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
The ONLY ratios that were available in these rears were: 3.08, 3.36, 3.55, 3.70, 4.11, 4.56. There was never such a ratio as 3.13,
ALLLLLLLLLLLLLLLLLLLLL of the above ratios were available in NON-posi and posi.
Changing the center section is a relatively simple task. With experience, the center section can be changed in 45min (MOST folks will probably require 1 1/2-2hrs).
Below is a comparison of posi(left) and non-posi 3.08 center sections.
Going from a 4.11 to a 3.36 or 3.08 will significantly lower your hiway rpm and noticeably improve fuel economy. The ONLY downside is that it will not be as responsive from a dead stop (and with today's gas prices, that is a non issue for me). Also, the ride will SEEM smoother (but it really won't be) because of less noise and vibration as a result of the lower hiway rpm. These cars NEVER had the ride of a full size 4dr family sedan.
If your driving is mostly local, I wouldn't.
Received 3,446 Likes
I have a 2.56 first gear in my '65 GTO with a 3.36 rear gear and I love it. Excellent all around gear. I like a 3.23 even better. But my 389 puts out about 430 foot pounds of torque....so that could be part of it.
Received 1,844 Likes
Take heed. What kind of driving and what kind of roads do you drive on?
St. Jude Donor '17
This thread is right on point for me. I have a 4.11 posi behind a close ratio 4 speed behind a 340 horse 327. I think a 3.70 would be about perfect for me. Lose a little acceleration and maybe a slightly sluggish take off but quieter highway operation, smoother, run cooler and better mileage. I have no idea as to the cost but I am guessing I would go with an aftermarket gear set. I’m going back to lurking now.
St. Jude Donor '07
the rule of thumb for drivability is 1st gear times RER should be at least 10. so 2.20 x 4.11 = 9.04 2.20 x 3.70 = 8.14 (worse...)
my SS700: 2.66 x 3.36 = 8.94 with ZZ4 engine (as I said, I don't like it, but too much trouble to change..)
my MY6 has/had a 3.09 x 3.36 = 10.38. a pleasure to drive around town and has an overdrive 4th gear
Received 3,052 Likes
C1 of Year Finalist (performance mods) 2019
I have 3.08s in my 57 with a Saginaw 4 speed (don't know what the 1st gear ratio is) and it is great but then again I have a 383 stroker engine 450-475 h.p.
My 59 has the 4:11 posi which is no fun on any kind of open road. I installed a T5 for the overdrive 5th. gear - changed the personality of the car. Still has the low 1st. gear while rolling effortlessly down the interstate with 70+ mph. traffic.
