[C2] 1966 Alternator Pully & Fan issues
Hello,
While installing a new fan belt on my 66 327 L79 I noticed the alternator pulley and fan are notched for a keyway. The shaft on my date matching alternator is not machined to accept the same?
What is going on here and how do I correct this??
Received 2,136 Likes
To me it sounds like the alternator on your car is a generic one from some parts place. What is the part number? The "date matching" one you refer to sounds like a correct replacement that the pulley and fan bolt onto the shaft. What is it's part number? Dennis
See why the confusion on my end.
Received 2,148 Likes
2015 C2 of the Year Finalist
Any leads on where this item might be obtained?
Thanks.
I find the rebuilders have access to parts that us end-users cannot always locate. Go talk to the electric rebuilders in your area, all you need is a 10DN rotor, should be easy enough to source.
The 10DN's were good, but they were not 150,000 mile propositions as many are today (I have 230,000 miles on a Bosch in an 18 year old Benz). Its likely it was repaired before you got it.
Dan
Dan
Dan
I believe your issue is with the pulley and fan that you currently have...if I'm reading correctly. The alternator is possibly original to the car but the '66 alternator shaft didn't have a groove for a key way and the original pulley and fan didn't either.
Received 1,844 Likes
That be what I'm thinking too!
It's a 327-350 L79 and has the deep grove alt. Pulley 3829387 which is set up for the keyway....so is the fan.
You need to talk to an expert.
While you're waiting, I'll stick with posts #'s 7, 8, and 9.
Sometimes a replacement part(s) are changed to accommodate other usages than the original design was intended but still carry the original part number.
Before you tear up a perfectly functional alternator, I'd wait on an expert to advise you. I'm certainly not one of them.
IMO it's correct for your car, there may have been another application for the part which used a keyway.
This is the GM alternator pulley listed for the L79, it does not have a machined keyway in it.
Good luck... GUSTO
Alternator Pulley - 3 5/8" O.D.
Paragon Number: 1651
GM Part Number: 3829387
Alternator pulley, 3 5/8" O.D., zinc plated. Part #3829387 and code AI as original.
Usage: 1965-69 & 1971 as follows 1965-68 w/327 Sp.Hi.Perf. and hyd. lifters. 1965 w/396 Sp.Hi.Perf. 1966 w/427 Sp.Hi.Perf. 1966-69 w/427 exc. P/S, and w/o A/C. 1969 w/H.D. 1971 w/454 Sp.Hi.Perf. exc. P/S.
Years 1965 - 1971
photo courtesy Paragon Corvette ReproductionsParagon Number: 1651
Years 1965 - 1971
Good luck... GUSTO
Good luck... GUSTO
Years 1965 - 1971
Years 1965 - 1971
Good luck... GUSTO
At this point I believe based on the opinions of a knowledgeable NCRS judge in my area, I need to source the part # 3829387 without the keyway.
The search begins.
