1967 Underhood Dimple
How do correct numbers get onto a block stamp pad of an engine that did not start life in that car?
mikelj (01-30-2018)
Received 1,844 Likes
What I want to know is what clown came up with the idea this was a defect in the mold and how did he substantiate it. It may have been on purpose?
Furthermore, does it really matter? Many had a new front end spliced on ahead of this pimple.
PS. Both my midyears still have the pimple intact. One of them has been repainted. Minor sandpaper scuffing doesn't removed the pimple. And it's a pimple in the fiberglass and a dimple in the mold.
very simple, maybe that area of the mold got filled either from daily use or maybe someone did not like it and they tried to correct it or the Mold Gods had something to do with it.
I think a better analogy would be how did verified factory mis stamps on trim tags or mis strikes on stamp pads happen?
uh oh, now your starting to get defensive. I thought you said you couldn't GAS?
Don't pay any attention to the crap I type out.
Received 6,979 Likes
2015 C2 of Year Finalist
Not exactly sure what you are asking, but the Dow (AO) Smith body production in Ionia Michigan ran from the 1964 thru 1967 model years only. It was all consolidated at the St Louis plant in 1968.
AFAIK Owens Corning had nothing to do with supplying the panels on C2s. Raw fiberglass matting maybe.
Received 1,391 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
You all are forgetting how important AO Smith was to ALL fiberglass: From John's post:
St. Louis-Corvette didn't manufacture ANY fiberglass body panels - they welded the birdcage together in the basement, primed it, sent it upstairs to the Body Shop, and bonded the body together around it, using fiberglass body panels molded, trimmed, and prepped for bonding by outside suppliers. Almost ALL the body panels were molded by A.O. Smith in Ionia, Michigan, with some smaller panels molded by others. There was only one set of molds for body panels, and the panels were used both at A.O. Smith on their body assembly line and at St. Louis on their body assembly line.
A.O. Smith-built bodies were assembled, painted, and partially trimmed (glass, exterior moldings and hardware, and interior garnish moldings and internal door hardware - just enough to make the body water-tight), and were shipped to St. Louis on tri-level rail cars; all interior soft trim, seats, carpets, pedals, heater/AC, and complete instrument panel assemblies were installed at St. Louis.
A.O. Smith built 50% of the Corvette bodies - the St. Louis Body and Paint Shops only ran on one shift, but assembly ran on two shifts. All orders for N14 Sidepipe cars (which required a unique birdcage) were allocated to St. Louis - no bodies for sidepipe cars were ever built at A.O. Smith.
It's possible for A.O. Smith bodies to have the same body number on the trim tag as a St. Louis body (ignoring the "A" or "S" prefix); both plants had separate (but similar) body numbering schemes, and coupes and convertibles had separate number sequences as well at both plants. For example, body number A-3407 on a convertible would be the 3407th convertible body built at A.O. Smith, and there would also be a convertible body number S-3407 for the 3407th convertible body built at St. Louis (same situation for coupes at both plants, which had number sequences starting from "0" just for coupes).
The following 3 users liked this post by mikelj:
Do care about knowing the history/details of my particular car!
I think we need to differentiate between body assembly and production of raw body panels.
So - where were the raw body panels produced? It seems like that for 1963 it would have to have been in St Louis? Nolands book shows on pages 36 to 38 pictutes of raw body panel production which are obviously not 1963, but doesnt say where it was located.
Proof you should never say never, when it comes to normal production automobiles. Or what an individual might be willing to prove if the pay is sufficient.:
#33
My understanding is that the Smith operation did not start until 1964, and that prior to that the Ionia plant had been the Mitchell-Bentley body company building Buick and Oldsmobile station wagons. The 1963 C2 bodies all came from St Louis.
And: "To clarify - there were two A.O. Smith plants that supplied the Corvette plant. One, in Ionia, Michigan, molded body panels and built 50% of the Corvette bodies from January '64 through the end of '67 production; this plant was originally owned by the Mitchell-Bentley Co., and was sold to A.O. Smith in late 1963, and became known as the "Dow-Smith" division of the A.O. Smith corporation. It later went through several other owners (Rockwell, General Tire, and others) as the fiberglass industry consolidated, and continued as the major supplier of Corvette body panels through 1982.
The other one was the A.O. Smith - Granite City, Illinois plant, which made Corvette frames from 1963-1967. 1954-1962 and 1968-1982 Corvette frames were made by a different A.O. Smith plant in Milwaukee, Wisconsin."
tuxnharley (01-30-2018)
#34
Obviously, there wasn't a single supplier or EVERY car would have the pimple.
#35
Yes, '64 is correct, also from John's post: "A.O. Smith started supplying bodies in mid-January, 1964. The same fiberglass panels were supplied to both plants. About the only visible difference on the original bodies is the paint treatment on the riveted-on underbody brackets and reinforcments and the radiator support; they were dip-primed black on St. Louis bodies, and were green zinc chromate on A.O. Smith bodies. A.O. Smith didn't have a black dip-prime system, and painted those parts in their birdcage paint system; required some extra effort in the underhood blackout operation at A.O. Smith to cover the green zinc chromate paint on the radiator support."
Edit - seems to have been answered in post #34, while I was typing the above.
#36
My car is highly modified: different frame, eng., Trans etc.
But the dimple is definitely there. To me that helps with my "no hit body" theory.
Before reading this I would have sanded it flat if I was painting the car. So, I can see the reason a lot of cars don't have the dimple.
#37
Hmmm - so, if the Ionia plant didnt start until January of 1964, where were the body panels for 63s and early 64s made? If all body panels after that were made there, were the molds/presses moved there? Were there two sets of molds to avoid a delay while moving?
#38
#39
Received 1,587 Likes
St. Jude Donor '20-'21-'22-'23-'24
It's a proven fact that the only 67's that got the dimple/pimple are the small block cars that got the big block hoods.
Steve
Steve
#40
Engaging in pure speculation now, but perhaps there was more than one supplier for the front top surround and thus different molds - one with the bump and one without? A way to distingush between suppliers, perhaps?
Strange that this would appear in both 64s and 67s!
