Adaptor for air cleaner?
I was wondering if anyone has ever seen an adaptor to allow use of an air cleaner with a smaller opening on a modern carb? I see adaptors in the reverse which would allow newer air cleaners on old Rochester carbs but I can't find anything that would let me use my original dual Snorkel corvette air cleaner on a modern carb with the 5 1/8" lip. In looking at the adaptors that are out there, it does not appear that I could simply flip it over to meet my need.
I've seen people cut these air cleaners up to make them fit but I'd never do that. I'm currently using a corvette air cleaner from a later C2 but it would be cool to get the correct look. I'm not concerned with power restriction as it's a low hp build anyway.
Received 1,844 Likes
See your local sheet metal shop and have them make you one.
Received 6,984 Likes
2015 C2 of Year Finalist
Easier to buy the correct carb so no mickey mousing anything.
Actually, that's my problem. I have the carb on it that I really like. It's super reliable and the engine runs beautifully in all conditions. I even get great mileage.
I also have the original carb on a shelf that will allow me to use the original air cleaner but every time I try to use old carbs, they disappoint me even when they have been professionally redone. From what I've read, the original Rochester carb it came with was nothing but trouble.
GM used Rochester/Q-jets in cars and trucks to the very end in the early 90’s. They are economical carbs not performance. Either your sending it to someone who is only slapping in a generic rebuild kit and cleaning or it has some bad parts on it. If it has bad parts a good restorer would find them and fix it right.
Received 1,974 Likes
This thread is like a riddle. Hmm... "dual snorkel" air cleaner, implies a '63-'64 250 or 300 HP engine, with the former having a WCFB and the latter a AFB, which have different air horn diameters.... but, wait, you don't have either of these types installed.
We do know the air horn diameter, but since I haven't memorized that dimension for every four-barrel carb design since the fifties, I can't hazard a guess.
I give up...
BTW, both the WCFB and AFB perform very well if brought back to OE spec and condition by a competent restorer that has a thorough knowledge of these carbs and a good collection of parts for those that Bubba changed or modified over the years.
There is nothing revolutionary about newer designs. The important thing is that the carb configuration is set up by competent fuel system calibration engineers and techs, like the GM guys back in the carburetor days. They spent a lot of time at the proving grounds calibrating the carb for each engine/transmission config. to achieve good cold start and warmup characteristics and good driveability, fuel economy, and performance under all operating and ambient weather conditions. It's somewhat of the black art that has been mostly lost, but they were damned good at it.
My thinking is that since you want to retain the original air cleaner, you are concerned about maintaining original appearance, so you might want to consider a properly calibrated, restored OE type carb.
Duke
I give up...
Duke
bodaboom69 (06-03-2022)
The following 2 users liked this post by MikeM:
64corvettekid (01-10-2018),
beekppr (01-07-2018)
My question was simply if there was an adaptor that allowed me to keep my current carb with a horn diameter of 5 1/8" and still use the original dual Snorkel air cleaner with a smaller horn diameter of 4 7/32". It would seem no such adaptor exists.
look at the post above you by MikeM
Thanks! I saw this item in my searches but I got the impression it would only work one direction. The link you posted shows some nice close of shots so maybe it would work for my needs. I went ahead and ordered it. For the price, it's certainly worth a shot.
Thanks everyone. I'll post the results for future reference. I know I'm not the only person who has wanted to use the smaller air cleaner on a newer carb since I see these air cleaners cut up from time to time.
2016 C2 of the Year Finalist
I think you’ll be disappointed in this for a fix. Even though the bottom ( for your app.) flange is the larger width, the hole is not big enough to seat on the larger carb body. I know. I tried to go from an Edelbrock carb to snorkel with this as a reducer. It won’t seat on the carb rim. Dave
Well crp. I ordered it so I guess I'll see where it doesn't work and go from there. I may have to have something made if it's that important to me.
Received 1,921 Likes
If there are any top carb protrusions, at that point just cut reliefs in your air cleaner base.
Separately, my '65 came from the last owner with a Rochester 4-jet carb which were never used on any Corvette, but was the most common 4-barrel square bore 4-barrel in the 50s and early 60s. These are cheap replacements in the used car bin for either WCFBs/AFBs/ and Holley 4150s, but they give up a ton in breathing capability. Yes, they are simple to tune, but at what cost?
Not sure what year Vette we are discussing or exact type of air cleaner you are trying to adapt. What I have done on a Mopar to adapt a newer Edelbrock carb on an engine originally fitted with an AFB was search out a later air cleaner base for the same diameter upper. Holley carbs with a 5-1/4 inch air cleaner were used on many of these cars. Possibly the base on the current C2 air cleaner you are using will fit the earlier upper air cleaner housing.
Mike, what carburetor are you currently using on your engine. If you're not sure, post a picture and someone will identify it.
On the chance it happens to be a Holley, have you considered just switching to a later open element air cleaner that Chevrolet used on a variety of Holley equipped SB engines? This one just happens to be for a '66-'67 SB, but they made a wide variety of different bases for just about and SB/BB equipped with a Holley.
Many were swapped out back then so they are certainly period correct for these cars.
https://www.paragoncorvette.com/p-35...-assembly.aspx
Good luck... GUSTO
Air Cleaner Assembly
Paragon Number: 1009K
Air cleaner assembly, includes triple chrome air cleaner cover. All w/327.
Years: 1966 - 1967
photo courtesy Paragon Corvette ReproductionsParagon Number: 1009K
Years: 1966 - 1967
Good luck... GUSTO
DansYellow66 (01-08-2018)
