Starting Restoration on the '63
#821
I believe It was John Z who said the the 63 caps were the most expensive caps to produce for any GM car.
Pat did you restore them your self. I know they are not easy to find in any condition .
#822
Received 1,958 Likes
I actually had two pretty nice sets. I took them all apart, had the flat serfaces polished. Then I cleaned and polished all the littles pieces. Then took the best of the best parts and assembled four of them.
Hope you're not suffering from the heat down there!
Pat
ptjsk (07-30-2023)
#824
Tip Top '63, Pat!
ptjsk (07-30-2023)
ptjsk (07-31-2023)
ptjsk (08-03-2023)
ptjsk (08-07-2023)
1969RAY (08-07-2023)
The following 3 users liked this post by ptjsk:
#835
Wait until you get hooked on this black oxide, does a real nice fast job…. you will never have to deal with any medium size metal parts, fasteners etc. from getting any rust on them & finish will resemble a very well preserved survivor….
Chalie
Chalie
ptjsk (08-08-2023)
#836
https://www.amazon.com/Caswell-BLACK...7-93deae8f9840
Chalie
Chalie
ptjsk (08-08-2023)
#837
I have never tried their official cold oil dip, but I have been using wd40 instead, (recommended on a you tube clip:-), so far with good results.
Is there cold oil dip any better just curious ?
thanks
Chalie
thanks
Chalie
#839
Hopefully this is the easiest oil discussion on this forum.
