Go Back   Corvette Forum > C1 & C2 Corvettes, 1953 - 1967 > C1 & C2 Corvettes
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-07-2002, 06:32 PM   #1
tuxedo
CF Senior Member
tuxedo's Avatar
Default Hood popping open while driving.
Any suggestions or tips on adjusting the hood latch/pin mechanism to keep my hood down. The passenger side rear hood area keeps popping open while driving. I have adjusted the hood pin spring both with more tension and lighter tension, checked the latch and spring tension which seems as strong as the driver's side latch which seems to work fine. The latches are only 5-6 yrs old. The only thing I notice is that front passenger side of the hood is is an 0125 lower than the front qtr panel hood area. While the driver side hood and panel area line up horizontally. Could this difference put the hood in enough of a bind from front to back to cause that assosciated latch to fail ever so slightly. ( The hood was taken off the car recently and was not put back by me. But it lines up with the scribe marks etc.). If so can I put some shims under the front hood hinge to raise the hood the required .125. I am hoping somebody has had this problem and can give me some advice.
tuxedo is offline   Reply With Quote
Old 10-07-2002, 07:10 PM   #2
stngry63
CF Senior Member
Send a message via AIM to stngry63
Default Re: Hood popping open while driving. (tuxedo)
After making sure that everything is adjusted properly, check for play in the front hinges. Mine were worn before I replaced them and allowed the hood to float horizontally and unlatch at the firewall.
stngry63 is offline   Reply With Quote
Old 10-07-2002, 07:14 PM   #3
waynec
CF Senior Member
My memory may be failing me, but I think the hood pin can be adjusted in and out from the hood panel a bit by loosening a lock nut at the base of the threaded shaft (which is part of the spring retainer) and turning the shaft. It would seem yours needs to be adjusted out slightly so that it fully engages the latch mechanism, but first adjust the cushion bolt atop the latch assembly so the hood rests on it and the hood surface is even with the hood surround... you can best make this adjustment with the (left) male latch pin removed from the hood.
And, check the left latch cable attachment adjustment to see that the latch is allowed to close as far as possible (ie, be sure the cable that connects the two latches is not keeping the left latch from fully closing).
[Modified by waynec, 3:20 PM 10/7/2002]
waynec is offline   Reply With Quote
Old 10-07-2002, 08:10 PM   #4
WADE1965
CF Senior Member
WADE1965's Avatar
Make sure that your hood release handle is pushed in all the way before you close the hood. Sometimes the spring dosn't pull it all the way back in and it causes the hood to pop up.
WADE1965 is offline   Reply With Quote
Old 10-07-2002, 10:50 PM   #5
magicv8
9 Hot Rod Power Tours
magicv8's Avatar
If the hinges are loose, get new ones or drill out the pins and replace them with bolts with nylok nuts. See the Details link of my homepage (below) for more info on this.
The installed height of the hood bayonets is 1.42 inches to the lower spring retainer.
Align the catch assembly by loosening the three fasteners that hold each one to the body.
Make sure that the cable between the latches alows them both to return "home"
Grease/oil them as necessary. Pictures are on F228 and F229 of the Assembly Manual. The Chassis service manual is vague about these latches.
magicv8 is offline   Reply With Quote
Old 10-08-2002, 12:03 AM   #6
6T5RUSH
CF Senior Member
Cruise-In III Veteran
Support Corvetteforum!
6T5RUSH's Avatar
tuxedo,
For what it's worth, just maybe... just maybe you are experiencing the same issue I had and that is the rubber insulation on that side somehow got loose enough to give increase resistance to latching. I realigned that rubber and she latches and stays down. Sometimes it's the little things. Worth a look at.
Good luck.
Jim
6T5RUSH is offline   Reply With Quote
Old 10-08-2002, 09:54 AM   #7
Ih2lose
CF Senior Member
Ih2lose's Avatar
Default Re: Hood popping open while driving. (magicv8)
Excellent advise.I am just fine tuning my hood adjustment.I am assuming that I set the height first with my rubber snubbers on my hood latch's first and then go for the realise? or do I do the relise first and then bring the snubbers up to to get the height and avoid rattles ?
I have been spending alot of time on body lines and fit and finish lately Also the details more and feel I am rasing the quaility of my car.I know this is what I admire when I am looking at an old car.
Ih2lose is offline   Reply With Quote
Old 10-08-2002, 12:13 PM   #8
magicv8
magicv8's Avatar
Default Re: Hood popping open while driving. (Ih2lose)
I would set the bayonet height, back off the rubber stops and set the latches so that the proper hood height is allowing easy open and positive latching. Put the snubbers barely against the hood after that.
[Modified by magicv8, 9:09 PM 10/8/2002]
Reload this Page Hood popping open while driving.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
