Routing front harness wiring on SRIII frame
For you who have an SRIII frame, where did you route your front wiring harnesses wires to the headlights and light Motors? Factory puts it on top of the inner fender well. Was thinking about the outside of the frame. Any help from you guys who have this setup will be appreciated.
Johnny J
Johnny J
I had asked the same question awhile back for my 63 resto mod. Some suggested conduit in driver wheel well and I think Mike at SRIII offers this option. The problem I found was securing the conduit to the inside of the fender, I ended up epoxying zip tie clips to the top and using some hosing as conduit.
Still not sure the whole thing is not a bubba move but the fender well is as clean as can be.
I ran all my engine operating wire along the frame as I mounted my battery in the rear.
See above the gas line positive cable to bat
I looked to see if I could find a picture of the panel but couldn't find one. Hopefully my description will give you an idea of what we did. It really worked well. Mike may have a panel for that purpose.
Rich
On our 63 Coupe we bonded in a length of fiberglass panel on the underside of the driver's side fender at the very top. It created a triangular shaped conduit which was large enough to run all the wiring and completely hide it. I repositioned the fuse panel into the recess originally used for the driver's side vent and ran the wiring up through a new hole so we could run the wiring into the conduit.
Rich
Rich
Yes this is the way to do it, next time
Rich
Rich
took some pictures of what ive decided to do....i found that i can run them right under the edge of the inner fender wells and then beside the hood hinge....have shuut the hood and wires dont interfere....I did consider making holes and runing inside outer wheel wells were the tires are, but decided I was ok with the wires showing...the nylon wovern sheathing makes it look sort of factoy (newer cars factory)....
