58 Trunk Spear Hole Size
Hi, I tried a search, but didn't find pics or details. The holes on my trunk were filled. I still have the original trunk, as the "tabs" are still on the back where the nuts once resided. Assuming the holes were radiused a bit when they were filled (I just stripped the paint down to the 'glass) wanted to get a measurement on the factory hole size before I go drilling. I'm assuming there was a little play on them ?
Thanks!
Thanks!
58 trunk chrome.
Thanks!
Thanks!
Hey Bill, thanks for the quick reply. Yep, I know how it goes. I located a repro brass set a while back. Has holes that I can install studs to. I mean, I can just make them fit, but I wanted to not drill them oversize if I can help it.
58 trunk spears
I can't remember the size of the holes but a couple were kind of tight so I used a rat tail file to open them up a little. Some people complain that the trunk lid doesn't stay up very good. Don't put your head in until it stops moving. Most of the time my wife just holds the lid or I put an umbrella under it.Hope this helps.BILL
Fixed it by switching to stiffer springs taken from a Stanley gate closer.
IIRC, they needed shortening but worked fine after dialing them in (may have added some short spacers...).
Thanks guys. I have a few leads on stiffer springs. Two things I learned from Carlisle this year - some of the high dollar 58's did not have an original trunk, and definitely not original spears. ;-) I will have a trunk that stays up.
