[C2] 396 MN questions
Old 09-10-2016, 05:39 PM
waveguerilla
waveguerilla's Avatar
Default 396 MN questions
Hi,
I have the opportunity to buy a 1965 C2 396 Big Block wich is matching numbers.
I hesitate a little because it's expensive due to the matching numbers.
It has been restored in canada in 2009-2010
Could you tell me if it seems a good deal ? Thank you.
Old 09-10-2016, 05:51 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
It looks like a very nice car with some minor modifications. I think at this point it would largely depend on "The Deal"...
Good luck... GUSTO
66jack
66jack's Avatar
How Much...$$$$
Old 09-10-2016, 05:54 PM
waveguerilla
105 000$
Old 09-10-2016, 06:04 PM
66jack
66jack's Avatar
Also, does it come with the original parts?
And why does it have 2 radiator caps...i thought big blocks didn't reservoir
Old 09-10-2016, 06:09 PM
Mr D.
Support Corvetteforum!
Mr D.'s Avatar
Received 1,486 Likes on 1,003 Posts
Is the engine pad cracked?
Old 09-10-2016, 06:15 PM
waveguerilla
Wich parts do you think about ?
I don't think so why did you say that ?
Old 09-10-2016, 06:16 PM
1snake
1snake's Avatar
There are MANY things that are incorrect on that car, The radiator is one. It also has a small block rear-end. The stamp pad is VERY questionable. It may be a nice car but not very original and WAY over-priced.
Old 09-10-2016, 06:21 PM
66jack
66jack's Avatar
Spare tire tub/lid
Rear spring
Exhaust manifold
To name a few
There is a crack to the right on the pad...
:::EDIT:::
All the stock front steering parts....
Old 09-10-2016, 06:24 PM
waveguerilla
Ok for the radiator, but is it really important because this one seems to be more efficient ?
And what is a small block rear-end ?
Old 09-10-2016, 06:27 PM
66jack
66jack's Avatar
I think what he meant to say was the half shafts are not a big block item as they used different caps on the u joints...beefier....
Old 09-10-2016, 06:28 PM
waveguerilla
Spare tire tub/lid
Rear spring
Exhaust manifold
To name a few
:::EDIT:::
For the parts, the man have all invoices of corvette central for parts that have been changed but I didn't look in detail.
For the crack, you're right, I will have to check it when I'll see the car again !
desertpilgrim
desertpilgrim's Avatar
Picture of the Trim Tag is needed. Was the car initially delivered in Canada so that there would be shipping records? By the way, April 3, 1965 was a Saturday.
Old 09-10-2016, 06:31 PM
Velox
Velox's Avatar
All big block C2 differentials used half shafts that attached to the yolks with caps and bolts, the small blocks used the U joints which are obvious in the photos you posted. It is easy to add rear sway bars to simulate a big block C2 but takes a little more work to change out differential parts.
Boyan
Boyan's Avatar
Default Rear
Big blocks had capscrews (bolts) instead of U bolts like small block cars. The 65's BB cars did have expansion tanks. This car has alot of questionable stuff for that kind of money.
Old 09-10-2016, 06:34 PM
1snake
1snake's Avatar
Actually, it's the side yolks in the rear end that uses the different caps. It's definitely a small block rear end, not a big block. Big blocks had shot peened half shafts but they look the same as small block ones. It's also missing the rear sway bar, another indication that this may be a small block car.
It also has a rack & pinion steering gear, wrong master cyl. valve covers and PVC system which indicates a different carb. than original.
Again, not an original car and overpriced.
Old 09-10-2016, 06:42 PM
jbalch
jbalch's Avatar
How is the car advertised, "original-nice driver?" If you pay that price, you'll have a very difficult time finding someone in the future that will. Like they say, there's a butt for every seat.....
To 396 MN questions
Old 09-10-2016, 06:54 PM
1snake
1snake's Avatar
In April 2014, it was added to the C-2 registry by a car dealer in France - http://www.c2registry.org/index.php?...te&car_id=2817
Old 09-10-2016, 06:56 PM
waveguerilla
Yes, the car is in France where I live, but here, nobody knows the vettes as you all.
Old 09-10-2016, 07:26 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Besides all that, the engine pad stamping (i.e. the "matching numbers") does not look original to me.
I would need a lot more inspection and a lot more proof that this was truly a factory big block car. I would also like to see the Trim Tag, block casting number and casting date, transmission numbers and dates, rear end stamping and date.
A pretty car for sure..............but way to many deviations from original to be a "matching numbers" car.
My opinion.
Larry
Quick Reply: [C2] 396 MN questions
