LS3 hood clearance in C2
Received 1,121 Likes
2017 C2 of Year Finalist
Does anyone know if an LS3 fits under a standard small block hood when installed in a C2?
Thanks,
Thanks,
OK, then, that's one down....
Now, how about any tunnel clearance problems with a 4L65E transmission attached to the LS3?
4l65e tunnel site:www.corvetteforum.com/forums/c1-and-c2-corvettes
Thinking about putting the 430HP LS3 & 4l65e "Connect and Cruise" system into a 63 convertible. Using a new stock repro frame and unmodified body. I'm hearing that it will fit (snuggly) without body mods...
The body is off. The frame is bare, ready for whatever. I can change anything, but would rather get a handle on all the probable changes before I do anything.
Sounds like I need to modify the engine mounts, cooling, fuel lines and tank, frame cross-member (to make it removable) for sure. Guess I'll need a stronger differential and half shafts. Any other major surprises or stuff I should study up on?
Thats a big advantage for sure. There are people on the forum that have done pretty much everything, plenty have raised the tunnel to make more room for bigger transmissions. I just shoehorned the LS3 into mine and bolted it to the muncie.
Did you buy the frame new ? Did you cross-shop the other frame options ? Not sure I would start with a stock frame if buying a new one and going the LS route, the more modern frames are setup for LS plus newer suspension, brakes, rear ends etc....
Thanks, that'll get me going...
I was going to use Tanks Inc. for an in-tank pump as electrics are noisy outside the tank.
I'm not gonna flog it, just a driver with the occasional run. The stock LS3 horsepower is really much more than I need. I don't think I can get enough tire under the stock body to really use all that power anyway, even if I wanted to. Could be that a stock diff and halfshafts are fine, I'll consider keeping them until i break something.
I'll alter the crossmember. The frame is a stock repro because I really can't get anything but C4 suspension on a custom frame without altering the body. C4 ride is bit choppy for me, so I'm leaving the C2 stuff on there, but may change the steering to rack and pinion.
