I just got my first C1 on the road
Received 1,296 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
My 61 has the original springs.. at 130K miles, it's nowhere close to "hard", only slightly "bouncy", and no rattles!
But maybe if it was hard it would rattle??
Received 1,275 Likes
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
My 1962 62,000-mile car is actually quite nice to drive . . . bearing in mind, of course that it is 53 years old. I wouldn't want to take it on a cross-country trip - both the car and I are too old for that, and I have a C6 convertible for longer-distance touring. For nice evening drives for ice cream, or a ride around the lake, it's perfect. To answer your question, if yours is hard, bouncy and rattling it sounds like it needs some work.
Received 3,777 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
No, they are not -------------------------- WHEN PROPERLY MAINTAINED AND SERVICED. And that is not always done by previous owners.
Admittedly, The entire frontend/steering is ancient technology. But, when properly rebuilt and aligned, especially with normal width wheels and radial tires, they do handle and ride quite well. No, they DO NOT have pwr steering and the brakes are std drums. BOTH work quite well if in good condition.
If the frontend is tight, with spec caster/camber (a little extra for radial tires) and the steering box is properly adjusted, they don't rattle, shimmy, or do "funny" things.
Stock rear springs are installed in rubber bushings--------which could be severely worn and need replacement-------------easy enough to do.
So with all of the above given good attention, they are a pretty nice driving car with virtually now rattles or harsh ride.
By the way, the 60-62 models are the best, because they have the latest upgrades and identical chassis/suspension.
The C1s have often been described as "fast tractors". Howver, I've gotten my '61 to the point that the wife prefers riding in it to my equally well maintained '63 coupe....
The ride is actually quite superb; now -- handling...that's another topic. The center link, king-pin, no power steering can be a handful and the car is pretty much a pig in fast turns. Straight ahead though and you float along wonderfully.
Don't forget -- the later C1s have 24 zerk fittings to grease (22 if the U-joints are permanently lubed) and attention to that might eliminate some of the squeaks and groans...
And, don't forget, this IS a sports car not a luxury yacht. A good set of gas shocks along with all the other recommendations will help to smooth it out, as well.
Received 4,584 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Modern radial tires and good shocks make a big difference. It shouldn't rattle. Mine doesn't and it rides pretty good for what is basically a 54 Chevy, turned "sports car."
jimh_1962 (06-28-2016)
Mike
http://chevy.oldcarmanualproject.com...62csg0007.html
Also, make sure your car has been upgraded to the heavier steering box grease too:
https://www.corvetteforum.com/forums...gear-lube.html
You need to get an ST-12 Manual -- from the online version:
The tough fitting to get at is the one labeled CL 14 towards the end of the transmission.
The drive shaft has to be turned just perfectly to align fitting so that the grease gun can get up in there. In fact, I ground down the sides of my gun to give me a little more room.
Well at lunch I went out and got an air powered grease gun, flex hose, std and right angle fittings, oil and filter, and diff fluid. I can't wait to dig in... Steering box, suspension grease fittings, rear end fluid and oil change.Mike
C-1 ride
I took my 59 to an old school mechanic for an alignment (no electronics that can move out of focus) Lubed and tightened anything that could rattle. This is a great car for cruising. Plenty of power for me (283 Hyd with two Carters) 59 navy
My buddy's stock '60 is what I would call hard-riding, hard-steering and poor-braking, compared to my nearly stock '67, which itself is hard-riding compared to anything modern, but brakes and steers well (Borgeson PS, PB).
When we switch cars at an autocross, he can't believe how easy my car is to drive; he routinely brakes well before an apex, then runs over the apex cone with the quick steering. In his car, I shoot past the apex on braking, the almost have to do a three-point turn to get around the corner.
I drive a stock '61 and a stock '63 on the same day MANY days. They each have their idiosyncrasies. The C1s are primitive....straight-line driving is as good as many classics and the suspension is adequate. Its a pig in fast turns even with radials. The '63 is more refined, doesn't really ride all that much better but handles sweetly -- the all drum brakes can get exciting on panic stops....best to have the lane beside you empty when doing so....
