61 high amp charge
Joe - I have been following your thread as I have been having a similar problem with my 57(stock generator and VR). Gauge operates normally except when I use turn signals, when it shows higher than usual charging on gauge. I would think it should show slight discharge at idle? Fine at cruising speed (normal charging), also discharge shown when lights on at idle. I've checked voltage across battery terminals and all seems normal. Very puzzling!
Received 2,153 Likes
2015 C2 of the Year Finalist
I think what he said was his needle moves between center and charge with his blinkers on instead of the other way around. Maybe his meter is wired backwards?
Dan
Dan
John
Folks should be aware that the GM (and GM licenses schematics) have the ammeter wires reversed in the document...doesn't hurt anything but your gauge will read backwards.
Dr. Rebuild's schematics have them correct.
I don't know that I'd let that bother me so long as its charging properly. My only guess is that you have a relay/timer type flasher unit instead of the stock thermal unit. The relay types can introduce reverse EMF (voltage) in the circuit each time the coil voltage collapses (bulbs flash off), just a guess. Look under the dash & tell us what kind of flasher unit lurks there.
Dan
Joe, it would be a good idea to periodically check the voltage at the battery with the engine running for a while (if the ammeter is doing strange things) just to be sure you don't have an overcharge condition which could damage things. Better to be on the safe side and it will give you peace of mind.
I drove it again today, all indication on amp meter and other electrical functions are normal.
Joe
Just curious, what is the purpose of the big (thumb size) capacitor on the amp meter ?
Do not think that is a factor in our analysis, capacitor either works or does not work...just curious.
Joe
Joe
The only capacitor on these cars that ISN'T for radio noise suppression is under the distributor cap
#33
Anyway, I'm back to the gauge/wiring on this problem. IIRC Devildog has a 500 horsepower beast crammed in his '61. I'm thinking during his high-RPM runs and when he's got the car bouncing a little starting up that monster; his intermittent problem occurs. I think a complete wiring chase down is called for and perhaps a gauge swap. Meantime I'd pull all the fuses and start it up cold just for grins and see if the problem occurs...
#34
Yeah - don't be getting too big for your britches down there in the hinterlands of Florida, not like you live with us highfalutin' folks near Disney
Frank, now lets not exaggerate my little SBC engine does not make 500 hp, it dynoed only 496 with 470 tq. It does not actually vibrate when I get on it, but does sort of try to do a climbing right turn in the old C-1 frame.
Joe
