60 Windshield Frame with 56 Door Posts
OK, now that I am in the final stages getting ready to assemble things while I was ordering door trim and seals I figured out that I have a 60 Windshield Frame and 56 Door Posts.
Has anyone used this combination in the past and are there any issues other than a mismatch of seals?
It is strange, when I look at the repro windshield frame from CC they use the same frame 56 -61. Not sue which posts they have reproduced but I will also give them a call.
I had a somewhat similar situation a couple of years ago when I bought rechromed posts for my 60. When I went to put my window channel in, I noticed that my left post was a 59-61 style and the right post was a 56-58 style.
I certainly didn't want to put 2 different weatherstrips on the car, so I studied the difference and determined that I could remove the "cap" on the right post (56-58 style) so it would match the left post (59-61 style). So, I got out my dremel and, with great trepidation, cut the cap off the right post. I took my time so I didn't cut off too much or make a bad cut or mar the new chrome. It turned out extremely nice. Both posts match and I can use the 60 weatherstrip for both sides. Before the weatherstripping goes on, all you can see is about a 1/16" line on the two top corners where the material was removed. This will be covered once I get the weatherstrip on.
IMO, you can use your posts as is and just get the appropriate weatherstrip, or you could do to both posts what I did to my right post so you essentially have 60 posts on your car.
Terry
Terry
Terry
Terry
Thanks for the reply!
"There are two variations of windshield frame posts. The 1956-58 version has a square notch relief for the door post with the upper window stop. The 1959-62 version has an angled notch to allow for the later style door weatherstrip, which features a built-in stop and continues over the door post."
http://tech.corvettecentral.com/2013...529.1429462198
