59 Overheating & fuel problem
Hi C1's
I have two problems with My 59 282 single quad First it gets very hot when in traffic but as soon as I drive it cool down. I changed the thermostat same problem. New aluminum radiator same problem. I have a original 4 fan blade. Should I put a auxiliary fan assembly?
Second problem; I could drive my car all day at a normal rate of speed but if I put the petal to the metal it pops , bogs down & wants to stall, when that happens I have to go in the slow lane, slow down for a minute or two than I can continue. Fuel pump, Vapor lock ?
History of motor; Complete rebuilt 2013
Thank you
Michael
Thank you
Michael
Hi C1's
Thank you
Michael
Thank you
Michael
Second problem could be spark plugs, plug wires misfiring under load, ignition coil, sticky advance weights, fuel delivery/fuel filter and a few other things.
Overheating at low speeds or idle could be a timing issue. Start at 10* to 12* advance. If you have a vacuum advance distributor you should be at 20* to 25* at idle with the vacuum can connected. Make sure your advance can is connected to a non-ported source at the carb. You should be "all in" at 36 to 38 degrees at 2500 to 2800 rpm.
First problem could be an inaccurate temp sending unit; verify temps you are seeing with a cheap I/R temp gun (Harbor Freight) has them...shoot the thermostat housing...you might not have an overheating problem at all. If that verifies your problem - might be time to look at your fan clutch and a few other things...
Yes I do have a shroud but a 1959 has no clutch.
Regardless of any other problems, you would be a lot better off running a 60 style 5 blade fan and fan clutch assembly instead of the original 4 blade fan. I do that in my 59 and it really helps. Zero issues cooling even on a hot day idling in traffic.
