Stinger Hood on a 63
What is the easiest way to use a big block hood on a small block car do you move the hood support to the left side or do you rework the hood support mount to the right side of the hood. My brother just bought a 63 with a 65 hood and wants to put a stinger hood on it.
Received 6,978 Likes
2015 C2 of Year Finalist
buy a BB hood with the mount on both sides. so you can use your SB hood prop location
We picked up an original 67 hood for a good price and plan to use it. I am sure someone has done the same swap.
I am just a hair late
Being your handle name is GS, I would have for a 1963 recommended the Duntov Motor hoods (they come in three styles) so you don't look like every other Corvette Owner on your block! And here I am recommending their stuff again for at least the 50th time, and have never got any perks! Maybe one day!
Back in 1969, I purchased a '67 stinger hood for my '63 and added a reinforcement plate on the left side to use my stock prop rod. I didn't glass the hole up, but then I wasn't as concerned about it as I would be today.
Good luck... GUSTO
Received 6,545 Likes
C2 of Year Finalist (track prepared) 2019
If the hood is historically accurate, the rear corners are rounded and would not work on a stock Sting Ray body which takes a hood with pointed corners.
Too, one would have to verify that the length and width and contour of their hood would be compatible with a Sting Ray body (if the rear corners were not an issue). The body contours of the handful of kit cars that have come from that company are significantly different from Corvette body contours.
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
In my opinion, FOR A STOCK, PRODUCTION Corvette, the coolest hood during the entire history of the Corvette is the 67 L88 hood! Even cooler than a 69 L88/ZR1 hood.
Our Most Favorite Hood
Don't worry, I am not one of their salesmen! They just have cool stuff!
You are probably thinking of their interpretation of a Grand Sport hood.
I have everything in your pictures, but mine aint NOS!
I am jealous! That is rare! But four of the hoods I have are vented like that to the cowl, but none of those are NOS!
I believe that if you do a search here you'll find a couple of folks have added a reinforcement to the right side of the hood, riveted it in place and then re-glassed the hole so it was almost invisible.
Good luck... GUSTO
Good luck... GUSTO
They cover the need to add material to the rounded corners. Some Vintage racers are running these units, but I haven't seen them on any cars outside of the GS kit builds! Yes the 1967, is a great looking hood but when I see one on a 63-66, I instantly think they are trying to be something they aren't.
Well I guess we almost agree, but not quite
Because I finally settled on the C3 L88 unit on my C2 with flares, because i have a GM Performance Bowtie high rise air gap single plane manifold with my Brodix turtle inside and carb spacer that i substituted in place of my old NOS shot plate, since I don't really street race anymore! All of that would never fit under a stock small block hood! Sorry, the big block hoods are on my cars as a by product of necessity "clearance!" I had to reposition the L88 air chambers to align to the small blocks and the spacer positions the L88 air cleaners into the vertical position into the open to the cowl vented chambers.
I don't know if they are still available, BUT the inside air box portion of the C2 (67) L88 hood is/was specified and part numbered in the Chevy parts book. You could buy these parts and turn any 67 stinger BB hood into an L88 cold air hood.......and one C&D writer (Pat Bedard) did just that
I haven't heard or seen a part numbered one being sold in a long time!
I don't know if they are still available, BUT the inside air box portion of the C2 (67) L88 hood is/was specified and part numbered in the Chevy parts book. You could buy these parts and turn any 67 stinger BB hood into an L88 cold air hood.......and one C&D writer did just that
I think pulling the air from the cowl is smart, no turbulance like with a front scoop. I opened up the L88 after the flow thru to the radiator so some heat is ascavated out prior to the carb and being the carb is sealed and pulls from the back cowl, I also opened up the firewall for engine heat venting up and out of the windshield vents. since i don't have a heater, the engine air exiting up and out helps keep the windshield defrosted!
My other issue with the 1967 Stinger is that i don't like non-functional shapes and a stock stinger is not opened to the front and then like in the NOS one shown, you have the insert closing it off, so it will vent from the cowl. The look is great, but those 1967 stingers hoods are non functional crap and i own two of them!
yes
I generally only like the looks of these big aggressive hoods when accompanied by factory sidepipes/covers or with headers and side exhausts pipes. Those big block hoods generally look out of place on cars with under car exhaust systems!
As I said in the beginning of this the car does not have a 63 hood and we like a stinger better than what is on the car. If he could find a 63 hood that he could buy for the money he could get this one for he would jump all over it.
