61 steering play
Old 12-20-2014, 05:54 PM
wfortune@snet.net
Support Corvetteforum!
wfortune@snet.net's Avatar
Default 61 steering play
I would like to take some play out of my steering if possible.
I have to turn the wheel to far either way before I get any response.
Front end in great shape, new radials, gas shocks and fast steering adapter.
Old 12-20-2014, 07:37 PM
plaidside
plaidside's Avatar
Received 1,126 Likes on 553 Posts
Do you have the ST-12 C-1 manual?
It has a detailed explanation of the the procedure.
Joe
Old 12-21-2014, 02:23 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,084 Likes on 4,737 Posts
Army
Joe (plaidside) is correct....but you have to follow that procedure precisely...get too carried away and you can ruin a good steering box....
Old 12-21-2014, 06:39 PM
John S 1961
John S 1961's Avatar
welcome to ownning a fine 1949 chevrolet, play is usually about 2 inches at the steering wheel
Old 12-21-2014, 10:12 PM
Ironcross
Ironcross's Avatar
Aren't they all that way.....
Old 12-22-2014, 12:55 AM
K2
K2's Avatar
If worm and roller and bearings are in good shape and adjusted properly there will be no to very minimal free play in the straight ahead position. As you turn the wheel off center play increases but that is the way that they were engineered and cannot be adjusted out. I replaced the gears and bearings in mine about 6 years ago and in the straight ahead position I have max 1/2" of free play in the wheel. 2", in my opinion, is too much to be considered normal.
Old 12-22-2014, 07:45 AM
plaidside
plaidside's Avatar
No. If the steering linkage is good and the box is centered on the 'high spot' and adjusted properly there should be no play.
Joe
To 61 steering play
Quick Reply: 61 steering play
