Cast Iron Powerglide
The cast iron powerglige in my '56 is leaking fluid from the vent valve located on top of the rear housing. I tried changing the valve and installing an extension tube to replace the vent valve but I still have the same problem.
Would anyone have a name and number of a transmision man who would be familiar with cast iron powerglide and could advise me on how I can fix this leak.
Any help would be apreciated.
Thanks,
Piere G. Joly
Thanks,
Piere G. Joly
Re: Cast Iron Powerglide (Pierre)
A CopperNic search found the following :
http://www.eastcoasttransmissions.co...lidgaskset.htm
http://www.oldtrans.com/
http://www.dencities.com/tampautotrans.html
Hope this helps.....
