Ominous Sign-Fuel Pump
Today, I fired up my '64 just to warm it up since it is not on the road. I saw a fluid on the top of the fuel pump after it started. It smelled like fuel. When these fail, will they leak fuel onto the top of the pump? If so, who has the best rebuild kit? Thanks all.
Thank you Chris. Just checked the Long Island Corvette and the rebuild kit is not available currently. Does anyone have any other good (not Chinese) sources for a rebuild kit. Thanks again Chris for the info.
I question if Rock Auto "AC Delco" stuff is legit AC Delco.
Some of the so called AC parts I have purchased there appear to be Chinese knock offs, complete with packaging.
Cruise-In III Veteran
Or if you're not focused on the "numbers" and want a quality replacement, just get an AIRTEX 4657 from Advance Auto or your FLAPS. They work well.
Jim
In God We Trust!
Jim
In God We Trust!
Oil
Don't forget to change you oil after the fuel pump issue has been addressed. When the pump goes south, it can leak fuel into the crankcase. Jerry
I just put an Airtex 4656 in my '60 about 2 weeks ago. Working fine so far. The pump in the car (replaced about 8 years ago) failed when the rocker arm return spring lost 3 loops and the pin retaining the arm slipped out. I'm amazed the car was running. I happened to notice the slipped pin when I was working under the car doing some other things.
I have attached some info from Airtex regarding the 4656 and 4657 pumps. I got mine from Amazon for around 42.00. including tax and free shipping.
Also attached some info on replacing the pump from me, 62Jeff and Coves4me.
Dave Z
