Looking for thoughts on Holley carb problem
Hey all, I'm having issues with my holley 1850. I just put the carb on the car. Carb is "new to me". While trying to adjust the secondary float, level, the car won't run with the float anywhere near the "sight hole". Bringing the float upward floods the carburetor with fuel before the float level gets even near the "sight hole". Yes, I'm bumping the fender to "see" if I'm close. Without ripping the carb apart completely, I'm thinking maybe a leaky (heavy) float??....anyone out there have experience with an issue like this?
Thanks in advance for suggestions
edit: primary float level adjusted fine.
2nd edit: Heavy float makes no sense....I'd be getting fuel out of the sight hole..... HELLO!!
Last edited by mid-year crisis; 08-11-2014 at 06:53 PM. Reason: added info...and heavy float correction
Thanks for the input Tripleblack, from memory, there's no way to check a power valve (other than visually) other than using a "power valve checker" is there??
If the power valve is blown, the car will be running eye-wateringly rich, and the plugs will soon get fuel-fouled.
Mityvac
Cheers, GA
Sorry, not a visual method
If the power valve was blown the car would never idle good on the primary side. If I understand your post, the carburetor adjusts fine on the primary side, correct?
If you lower the fuel level on the secondary bowl it runs normal.
PAmotorman- Thanks for the input. From other research I've done, it sounds like that's a possibility, as well as secondary float getting hung up on secondary metering "plate". I guess it's time to dig in!
That is correct...to the extent that a car will run "normal" on one float bowl!
Thanks again to those who responded. I wish I could post the resolution, but after tearing the carb apart I couldn't find any glaring issues, other than possibly a warped metering body. I ended up throwing a rebuild kit in another carb, runs like a champ.
I had similar issues with my factory Holley 2818. I sent it to Craig Woodruff Performance in Youngstown, Ohio. He Milled the body of carb, base plate, and put in new metering block. He recolored it too, so it looks new. I put a double pumper on in the interim period, and just left it on. But he did a nice job for good price, if you want that one fixed.
