Parking Brake Light bLinks or Headlight Warning L:ight Blinks 66
66 Owners Manual says when Parking Brake is on therw a warning STEADY RED LIGHT on Dash/ Also says Red Dash Light Warning of Headlights on but Not in Open Position should BLINK .... My does the oppsite Parking Warning Blinks but HeAdlight Warning is steady...thus is Manual wrong or corrector or is my 66 is wrong?? Is my car is bulbed or wired wrong? Which is correct? Thanks
Switch your bulb sockets on the Cluster...
You might have them plugged into the wrong socket...
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
In 1966 both the brake warning and headlight warning bulbs blink. It is just the bulbs are wrong. 67 was the first year that brake light stayed on because it is tied into the brake system to show a pressure loss on front or rear of the system.
That's a bad idea. When you pull on the brake the "lights" will light up and vice versa if you switch the sockets. Do like the others said and put in the correct bulbs if you want them to blink.
Received 6,929 Likes
2015 C2 of Year Finalist
Make sure you give the bulb time to warm up. The 257 bulb takes a little bit to warm up before it starts to blink
OK Thanks to all Yes I guess the WRONG BULB is in the Haedlight one as scokets are Correct..since both operate with correct Headlight on or Park Brake on so Sockets are correct no need to switch thatd make situation worse...Ill either change BULB or leave alone..I have a zillion other tweaks in front of me. Till later Regards.....
