High Pressure Fuel Hose VS Regular Fuel Hose
Every year or two I have to replace my rubber fuel hoses due to hardening and cracking thanks to ethanol. Does anyone use the high pressure fuel hoses instead of the regular hoses? I know there is a plastic type liner in the hoses and I was not sure whether a hose clamp would properly secure it. Thanks
Received 2,127 Likes
Tell us what engine and carb you are running. You might actually be in line to use factory hard lines. Dennis
St. Jude Donor '07
i am using the high pressure hose on the supply side of my EFI, the regular hose on the return side.
both types seem to be holding up.
Bill
Bill
Received 1,843 Likes
http://www.gates.com/oreilly/tech_ti...elLineHose.pdf
You should be able to draw some conclusion as to what you need from this Gates publication.
I use SAE spec 30R7 and I don't have any problem with rubber fuel hoses and ethanol fuel.
The SAE spec should be imprinted on the hose.
Here's an article I wrote about hoses last year. It deals with race cars for the most part but the information is good for all cars.
btw - I've sworn off ethanol in my collector cars. I found "recreation gas" at my local Marathon station. I have 4 5-gallon cans that I fill and take to my cave when it's time to drive one of the cars.
Also, if the car is going to sit for more than 30 days I pump all of the gas out.
Richard Newton
Richard Newton
