I put an "always-on" dashcam in my car.
I hope I'll never need it.
It is a Mini-801 HD mounted in front of the rear-view mirror.
It will record about one hour in 5-minute length video files.
Once the flash fills up (internal 8GB), it will cycle through deleting the oldest files first.
It continues to record one hour after I cut off the engine.
It automatically powers on when I start the car.
Video is pretty good, audio is OK.
I've got a 32GB mico-SD card on order (will give about 8 hours of video).
Stamps video with GPS locations, and records locations to a log/time file also.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
With a 32GB mini-SD card, we get 2 hours of video, not 8.
Also, recording shuts off about 1 minute after the ignition is turned off.
For anyone thinking about getting one of these cameras, a couple of things to know:
1. The GPS function is optional and exists in the mounting foot. Be sure you know what you are buying. For some screwy reason, a camera which is set up to expect a GPS foot will work with a non-GPS foot BUT the converse is not true: You can NOT add a GPS foot to a camera not factory configured to work with GPS.
2. The 8GB memory is also optional. With 32GB of removable memory, I saw no advantage to having the internal memory so neither of our cameras were purchased with it.
3. In use, the camera gets pretty warm and I'm not just talking about being warmed by sunlight through the windshield. It generates a pretty good amount of heat all on its own.
4. The wide angle lens has no sun shade and glare when driving in the general direction of the sun is pretty bad. I'm going to make some kind of "awning" for the lenses of our cameras to see if I can cut down on the glare somewhat.
5. The Chin-glish in the manual is difficult to understand. Actual operation and set up is pretty simple once you figure out what the author was trying to say.
Bottom line: Overall, not a bad camera for the money.
Jim
I've been using the SmartCam HD 2 from dashcamusa.com
very nice camera.
very nice camera.
Anyway, you can use a lower-res codec (such as a 720p) and times go way up.
Not sure I understand the reason for this front facing camera in the car.... ??
Afraid someone will back into you ??
Fun later watching the road go by at high speed ??
I would be more afraid of having my Vette driving habit captured for later review by who knows who... Humm....
Search youtube for "dashcam" and you'll see a million reasons it'd be handy to have one, in addition to watching the scenery.
People actually do backup into the vehicle behind them to initiate insurance fraud. This kind of thing is insanely prevalent in a few countries, like Russia. That's why there are so many dashcams there nowadays. Also, most of that crazy meteor footage a few months ago was from dashcams.
Not true.....install a Power Magic timed delay power feed. Is programmable from one hour or more power delivery to camera AFTER power is shutoff (even from the battery-disconnect).
Not true.....8GB IS OFTEN SOLD CHEAPER than one without memory at all....go figure. Price before you buy.
In any event, internal memory is an option.
Jim
The thread is about my setup, which records for an hour after I turn the car off.
http://www.blackvue.com.sg/power-magic-pro.html
" acts as a countdown timer where user can set the preferable duration to have the [Mini 0810] operates when parked."
What I wrote about the camera shutting off after power is cut was and is accurate. That's a trait of the camera in general, not just the ones I own.
I'll post some pictures of my one-hour setup when I get some better ones taken. One hour (programmable to eight??) gives me piece of mind when I leave the car. These things run hot, so I've also made an aluminum heat-shield which doubles as a sun visor for the camera. It blends it better with mirror giving it better stealth. The cable is hidden inside the passenger side windshield pillar.
I had direct-power to the battery already run for my receiver, so a lot of the wiring had already been done.
