1961 Tachometer Problem.....
Old 07-24-2014, 10:53 PM
Blacksburg Hokie
Blacksburg Hokie's Avatar
Default 1961 Tachometer Problem.....
The tach in my '61 stopped working recently. I had it rebuilt 3 years ago. About a month ago, the cable got so tangled that it split open the casing around the cable. I replaced the tach cable but it still wouldn't work. I took off the generator gear and clean it and lubricated it, still wouldn't work. I connected my drill to the cable and ran it CCW and the tach only reached about 500 rpm. So I am thinking the problem is in the tachometer. Any other thoughts?
Thanks!
Old 07-25-2014, 05:04 PM
Blacksburg Hokie
Update: I went back in and rechecked the nylon drive gear. The nut that holds the drive gear on the shaft was a little loose. Tighten it up, lubricated again, and made sure the cable was seated, and all is good now.
Old 07-26-2014, 09:11 AM
wraplock
wraplock's Avatar
my tach isn't working now that it's installed in the car but as I recall it worked fine on the bench. Where is the gear you are talking about? Thanks
Don
To 1961 Tachometer Problem.....
Quick Reply: 1961 Tachometer Problem.....
