63 Stalling Issue
63 Stalling Issue
Just got the car back from paint.
Before that, installed a rebuilt 327/300HP, nothing special all new standard components and upgraded distributor. Never had the engine going since it was scheduled for paint. Tried to get the car going yesterday, but it will not stay running. Haven't been able to set the timing yet, but verified distributor is lined up close. Here's what it does; starts fine after a couple pumps of gas, runs smooth for 5 seconds and then just stalls - no sputtering or spurts, just dies. I can keep it going if I feather the gas or hold at high RPMs. AFB Carb was rebuilt, but sat for a while. Gas is old and gas pump is new and looks to have pressure. Any help on where to look next would be greatly appreciated. BTW, there is a car show this weekend, no pressure.
Check the bowls in the carb, or the screens see if you have small pieces of debris, if so change your fuel filter. Had a similar problem years ago, was using the ORIGINAL G90, for NCRS Judging, it was so old the insides were dissolving breaking very small pieces off and getting stick in the jets and in the carb areas..... Hope this helps.
Sounds like a fuel problem to me, you may want to disconnect the fuel inlet line and get a small catch can to see how long it takes the fuel pump to fill the can.
If you are satisfied there is no fuel pump issue the only other thing left is to remove the top of the carburetor and have a look.
How long did the carburetor sit with gasoline, the main well could be gummed up with old fuel.
Received 2,127 Likes
I agree with the above assessment! Very nice looking '63. By the way? Where did you get the idea for your stripe? It looks very familiar. Dennis
